power windows for honda civic hybrid
Old Jan 7, 2007 | 12:34 AM
victord's Avatar
Default power windows for honda civic hybrid
I just bought salvaged 2004 Honda civic that was flooded, car runs fine but my power windows don't work. Only front passenger windows rolls down, can anyone help how to troubleshoot this problem also my heater only blows hot air and in one mode that is on legs. Does anyone have any suggestions. I would really appreciate.
Old Jan 7, 2007 | 08:56 AM
cb450sc's Avatar
Default Re: power windows for honda civic hybrid
Sounds like you have your work cut out for you. Good luck with it.
Old Jan 8, 2007 | 09:03 PM
msantos's Avatar
Eco Accelerometrist
Honda typically implements the power windows control in an enclosed control module (small box) situated on the driver side - either on the door - or on the dash near the door. I believe this module may need to be replaced as it may have suffered damage from the flood.
I actually believe you have alot more damage than what you may be seeing. In time many components and systems in flodded cars will worsen and fail if they are not properly inspected and replaced. I suspect the blower assembly solenoids may have also been affected and they may need to be replaced.
The only true good solution I can recommend is that the car's interior trim be removed and inspected for water retention and other damage. The wiring as well as other components such as relay, solenoids, connectors and enclosed circuits such as power window control module and others may also have to be physically and expertly tested. Then you have the issue of the IMA power control module in the rear seat... which is a a deal breaker if it shows damage of any kind.
If you want to do it yourself, you will definitely need the shop manual and other insightful literature that Honda provides. Otherwise you're better off leaving it with a Honda professional or another caring shop if you want to have it done right.
Good luck.
MSantos
cody07hch
Aug 18, 2019 09:11 PM
KimikoPi
Mar 28, 2010 11:29 AM
wiredup
Aug 17, 2009 01:17 PM
Lansing
Oct 27, 2008 03:43 PM
EricGo
Sep 9, 2005 10:40 AM
