p1446 issue, I have changed every thing.. need help
Old Dec 21, 2022 | 05:26 AM
  #31
Nicolas Tremblay's Avatar
Default Re: p1446 issue, I have changed every thing.. need help
What about EnnoCar? they can ship at home for 1209$usd for 11 brand new cell.
Anyway review on it?
Old Dec 21, 2022 | 05:38 AM
  #32
All Chinese cells are inferior to the Panasonic/Sanyo cells. Period. Even compared to healthy ones that are 20+ years old at this point.
There is essentially no warranty if you purchase direct. If you have a problem, all troubleshooting and diagnostics are on you. If a subpack fails, the first claim is that the BCM damaged it. If they concede and offer warranty, they often require you return the failed subpack(s) - which costs notably more than buying a replacement as shipping TO China is very expensive. If they do finally provide warranty, the subpack you get will be new, and likely a bad match for the other subpacks. You will need to recondition the other subpacks to bring them back to the point they perform acceptably paired with a new one.
If you buy from a legit builder, you get a full pack.
Old Dec 21, 2022 | 05:46 AM
  #33
ok thank.
I’ve look a lot around and did’nt find any other battery builder neer by. they are all in the usa.
I did’nt even found any hch2 of crz to sale neer by. Only option look like scrap the car.
Old Dec 21, 2022 | 08:30 PM
  #34
So, they did refound me, and give me back an « old » batterie for the coore.
Long story short, the « old » coore was disasembly so they give me an other « good » « rebuild » batterie instead.
Plug it in = ima.
I got home and looking b connector voltage and 3 paires has no voltage.
Open the batterie and saw the little shim plate that it crack. Seem in SS, I was tinking to weld it back, will it work?
I will follow the self discharge of this pack during chrismis, in case by chance that this batterie is good…
thank
Old Dec 21, 2022 | 08:31 PM
  #35
Insist they replace it with a good one.
Old Dec 22, 2022 | 10:30 AM
  #36
They have refound me, I will not go back to this shop again.
But instead of giving me a scrap batterie, they give me a supposed good one. Voltage haven’t drop in any subpack overnigh, I’ll continue to monitore it. so maybe this pack will finaly be good…
Only need to repair the 2 shims.
Old Dec 22, 2022 | 11:33 AM
  #37
Fair enough.
Welding is almost certainly too aggressive and will consume the thin material. soldering may be more viable.
It's usually right here where some hamfisted jacka$$ breaks them:
Old Dec 22, 2022 | 12:31 PM
  #38
Plan A : buy new part : did’nt found any
Plan B : repair the thing: ain’nt worked
Plan Z : made that shity thing 🤣🤣
Old Dec 22, 2022 | 12:40 PM
  #39
If it works, it works. Just make sure the bolt is centered, and the pressure is even. Torque to 60 in-lb.
08escapehybrid
Sep 9, 2016 02:45 PM
rlalford1
Honda Insight
Aug 5, 2010 05:43 AM
chiedoziedike
Apr 3, 2008 09:32 AM
EZ2beGreen
Jul 10, 2007 09:54 AM
helterskelter683
Aug 17, 2005 08:17 AM
