Just installed new Navi, Backup Cam, and Bluetooth!!!
Old Nov 29, 2006 | 02:19 PM
  #71
EKL's Avatar
EKL
Default Re: Just installed new Navi, Backup Cam, and Bluetooth!!!
The after market kit color doesn't match 100% to the grey/brown color. If you want to do right the first time, buy the one from dealer and find a good installer to custom fix it for you. I think I paid less than $50 from dealer. Everything matchs perfect and looks OEM.
Check out the above pictures from UJJ. I think his 06 Civic Hybrid is Silver with the blue interior and I think he used the kit from dealer too.
PS I don't know what kind of Navi unit you are getting. But with all the options you can install and cables at the back of the unit not every unit can fix in. You better find a good local retailer/installer to do the work because if it doesn't fix it will be a pain to return the Navi unit via mail while your dash is all open ups. Good Luck.
Originally Posted by exbauer
Does the grey match the fatory blue pretty good?
Just a heads up that there is no aftermarket dash kit of the blue interior hybrid Civic. When I went to order my navi unit from Crutchfield they only had it in grey and brown (the only colors they makei it in). The stock colors for non hybrid Civics. The only place you could get the blue dash kit was from Honda and it retailed for about $99. If you got it from www.hondapartsdeal.com it was only $66. But, the non hybrid versions were only $44 retail, and $32 discounted. That is double the price!
Old Nov 29, 2006 | 06:29 PM
  #72
exbauer's Avatar
I was going to get the AVIC D2 or an Eclipse AVN 5500. But, I found out about the dash kit when I went to install it. Luckily I didn't take anything apart. But, it is an easy return since I purchased it from Crutchfield. I am waiting for my dash kit in blue to come in before I install anything. I wonder why the blue one is so much more expensive?
Old Nov 29, 2006 | 06:31 PM
  #73
exbauer's Avatar
did you get your steering wheel controls working? how hard was it to get it working? any tips on the wiring?
Old Nov 29, 2006 | 07:19 PM
  #74
EKL's Avatar
EKL
Yes, but my first installer tried for 8 hours and only able to get the volume and the channel up/down bottoms working....then he give up. My 2nd installer found out that he have to add some kind of resistor between the line to get the Source bottom working and then do the correct programming. Now everything work fine!
The lesson is don't take "No" for answer!
PS Check out this deal @ Costco.Com: http://www.costco.com/Browse/Product...1&Sp=C&topnav=
Old Nov 30, 2006 | 06:34 AM
  #75
ujjnath's Avatar
I used the same installer as Eric and my steering wheel controls work fine with no problems .. first time. I am not sure of the resistor, but there is a wiring kit that needs to be bought from Metra (?) I cannot remember the exact name, but if you want to .. I still have the original box and can get you the part number. Also, my dash kit came from the dealer and it matches fine.
Ujj
Old Nov 30, 2006 | 07:07 AM
  #76
exbauer's Avatar
yeah, i know you have to get an adaptor. i know pac makes one, just depends on which head unit you are getting. yeah, i got mine from the dealer also. just waiting for it to arrive.
Old Dec 1, 2006 | 04:55 PM
  #77
WRXSTi's Avatar
I installed a AVIC-N1 with iPod, bluetooth, and Sirius. My steering wheel controls work great. I used the PAC controller and programed them to my preference. Everything works.
I've installed a few head units in my time to be familiar with the process. Hooking up NAV and the PAC were new. Unless you have expierance at it or really good at figuring things out I recommend you to have it professionally installed.
IMO the Metra kit for a 7" unit is made horrible. The plastic bends and barely allows the N1 to be mounted properly. I recommend doing the research and getting the OEM pieces.
You can see my post here for more PAC information
http://www.8thcivic.com/forums/showthread.php?t=16009
and here is the finished product...
http://www.cardomain.com/ride/2481187
notice the Metra trim plate does not completely fit flush. When the motivation strikes I'll be switching it out for OEM pieces.
Old Dec 2, 2006 | 08:04 PM
  #78
exbauer's Avatar
wrx sti, does metra make it in blue? i got the oem one, but just curious since scosche doesn't make it. i have yet to install mine, i am just getting every first.
Old Dec 3, 2006 | 10:16 AM
  #79
WRXSTi's Avatar
I used metra kit 99-7871, my interior is blue and the match is almost perfect. Any closer in color IMO would have to be from Honda.
I was concerned with color matching as well and think its fine.
Old Dec 3, 2006 | 02:54 PM
  #80
exbauer's Avatar
thanks for the input. your setup looks really good. wish i could afford the avic z1. but, i will just be using it for navi purposes and don't need the extra dvd capabilities.
