Honda Civic Hybrid Questions
Old Aug 10, 2007 | 11:06 AM
AJR's Avatar
AJR
Default Re: Honda Civic Hybrid Questions
Originally Posted by nark
no, when you see the green bars, it means the electric motor is charging the battery. When the white bars show up it means the electric motor is doing work to help out the ICE.
A slight correction... when you see the green bars, the valves are closed in the ICE which is using the energy that would normally be used to propel the car [if the valves were open] to charge the batteries. You'll notice when you let off the gas that the number of green charge bars is relative to the speed you are going due to more energy in the system to regen the battery (15-35 shows ~1-2 bars, 35-50 shows ~3-4 bars, 50+ shows ~4-5 bars).
Old Aug 10, 2007 | 12:08 PM
kristian's Avatar
Originally Posted by AJR
A slight correction... when you see the green bars, the valves are closed in the ICE.
The valves can also be open when you see green bars, but in that case your iFCD isn't pegged at 100mpg...
Plinkonium
Jul 1, 2012 03:42 AM
GreenBoy
Sep 4, 2010 03:16 AM
1800collect
Apr 9, 2009 10:52 AM
MBNorCal
Mar 14, 2007 07:47 AM
tigerhonaker
Oct 10, 2005 06:24 PM
