2006 Civic Hybrid has shifter locking
Old Jul 11, 2015 | 08:00 PM
Default Re: 2006 Civic Hybrid has shifter locking
You getting a flashing CEL, CEL codes or just "feel"?
If you don't know the age of the plugs, should consider replacing (qty 8, OEM style DENSO or NGK only).
There is one coil pack per spark plug. I had to replace one. RockAuto has the OEM style (Hitachi made) for about $45. I had the luxury of swapping packs between the two cars before I committed to a replacement.
Good luck,
Steve
Old Jul 12, 2015 | 05:39 AM
Bobs Hybrids's Avatar
Thanks Keith. Car had 228000 on register when I bought it. Now has 233000. I have a parts car, so I can do your procedure with the coil packs.
Old Jul 12, 2015 | 09:55 AM
Totally forgot about that. Since it's a bit of a pain to get the driver's side rear pack out, I swapped out only the front, and I got lucky.
HCH2 #2 had about 212 on the clock when we got it in 10/14. The plugs were absolute toast. Flashing CEL (active misfires) and misfire codes on all cylinders. New plugs cured all the misfire codes, but there was a slight "stumble" or hesitation that was noticeable under any significant acceleration. The new coil pack fixed that.
Have you cleaned out the EGR ports? Your high mileage almost guarantees it needs it as it's likely not been done.
Old Jul 12, 2015 | 07:21 PM
Got both cars pulled front to front in shop. New plugs first thing in the morning and if it still misses, then to coil pack swap. Thanks.
hybie1
Aug 19, 2008 06:07 AM
2009CAM
May 23, 2008 04:33 AM
mikieboyblue
Aug 30, 2007 12:06 PM
MacBrando
Apr 7, 2006 09:06 AM
peggy
Sep 16, 2005 07:13 AM
