Xenon headlights install
Old Nov 14, 2006 | 07:18 AM
livvie's Avatar
Default Re: Xenon headlights install
You should check if the JDM market has an HID projector light housing for the HCHII. I supect they do. Also, most HID projector housing have a self leveling mode to minimize blinding oncoming traffic.
Old Nov 14, 2006 | 07:16 PM
mexiken's Avatar
I've looked around and around for some, but can't find any. What is the JDM market though ???? I got the lights to turn WAY down. Doesn't hurt how well I see, and DEFINITELY made a difference when I stationed the car and drove by it repeatedly.
Old Nov 15, 2006 | 06:27 AM
livvie's Avatar
Japanese Domestic Market.
Old Nov 15, 2006 | 08:43 AM
felixdacat's Avatar
Pimpin ain't easy!
JDM: Japanese Domestic Market
Old Nov 21, 2006 | 12:43 PM
jg44118's Avatar
Originally Posted by ralph_dog
Look at the front of the headlight assembly and if it has HB2 or HB3 (halogen only) on it you cannot use zenon discharge or HID lamps because the reflector will cause too much glare. You will need to purchase a new reflector/headlamp assembly that is specifically made for HID headlamps if one exists for your model vehicle. Hope this helps..
Regarding your article on xenon headlights. I have a 2007 Toyota Camry. Unfortunately, as you are probably aware of it does not come with Xenon headlights. Toyota doesn't make a kit for it either. If the Prius Hybrid has the Xenon lights can't that same kit be put on the Camry?
Old Nov 21, 2006 | 01:30 PM
felixdacat's Avatar
Pimpin ain't easy!
You cannot because the OEM base of the HID bulb of the Prius is for specifically OEM HID fitted bulbs. You would need to buy a rebased hid conversion kit. Example: Since your bulbs are 9006, you would need to get an HID rebased conversion kit for a 9006 bulb.
http://www.xenondepot.com/product.php?product_id=17 (they sell cheaper ones on ebay of course)
pagemap
May 13, 2010 12:58 PM
joltheadq
Feb 9, 2009 08:27 AM
meerkat
Feb 18, 2007 12:42 PM
errlin
Jan 30, 2006 10:50 AM
BigBill
Nov 13, 2005 03:26 PM
