Seat Belt chime not activated by body shop
Old Jan 12, 2010 | 06:02 AM
MyFirstHy's Avatar
Unhappy Seat Belt chime not activated by body shop
Hi all. Tried some searches on here, but found nothing that helps...
I recently got into an accident with my 2007 HCHII and upon getting it back from the body shop, I noticed that the seat belt chime does not sound anymore. They had to replace my seat belt, since that was part off the sensor kit for the airbag which was deployed.
Example: when I would come home from work and pull into my garage, as soon as I was in far enough, I'd unlatch my seat belt. The chime would then sound (noting that I was still "driving" but I was unbuckled). It no longer does the chime. Can I enable the chime myself some way or does the body shop does that? Since they are not a Honda body shop, would you even think they'd know about it?
One more thing...they also broke my cruise control switch, so my cruise control doesn't engage currently, either.
Old Jan 12, 2010 | 07:05 AM
mrkcohen's Avatar
Moderator
Default Re: Seat Belt chime not activated by body shop
back to the body shop until they fix it right...
Old Jan 13, 2010 | 04:55 AM
bengteck's Avatar
the connector located below the driver seat, wonder if they connect back the side airbag connector too?
for cruise control check no 12 fuse under hood fuse box and no 3 under dash fuse box
jd702
May 6, 2010 07:45 PM
Sky Blue
Jun 2, 2008 12:47 PM
EOppie
Dec 8, 2007 06:27 AM
myraellen
Apr 5, 2005 06:36 PM
