My Hybrid finally had a problem
Old May 13, 2009 | 10:01 AM
iridium130m's Avatar
Default Re: My Hybrid finally had a problem
i would highly HIGHLY recommend that anyone owning a hybrid invest in the extended warranty...especially since the 7 year portion is not comprehensive on all of the hybrid parts.
So ending to my story: dealership reduced the overall price of the repair to ~900 and american honda is covering half of the bill. I am much MUCH happier now. I asked the service adviser if I can purchase the extended warranty out of warranty and she said yes, so I'm researching those options now.
I am thoroughly content with their response...my wife and i have owned or leased 9 hondas in our lifetime, and i was about to trade both our civic and our odyssey in for either subarus in the next couple of months. Crisis adverted.
Old May 26, 2009 | 08:58 PM
drozzin's Avatar
Hello HCH owners,
Did you see any precursor of the problem with rotor position sensor such as lack of power, jerking etc.?
Old May 27, 2009 | 08:08 AM
When the position sensor fails, you will see several fault lights come on, and the autostop function will stop working.
Old May 27, 2009 | 09:55 AM
drozzin's Avatar
I mean BEFORE the actual failure was anything unusual in car's behavior?
Old May 27, 2009 | 11:05 AM
Well, if you are looking for pre-failure symptoms there were none, as nothing had failed yet.
Old May 28, 2009 | 11:59 AM
Originally Posted by drozzin
Hello HCH owners,
From day one I've always had a "bump start" issue where when the car went into Idle Stop and i then lifted off the brake before coming to a complete stop or quickly after reaching a quick start, the car would drop the clutch and it felt like I got hit from behind lightly. Now that the sensor is replaced, I haven't felt the issue at all and have not been able to force it to take place like I was able before.
Old Jan 7, 2010 | 05:45 PM
  #27
bar10dah's Avatar
Has anyone seen a P15A5 combined with a P0000?
Old Jan 8, 2010 | 12:12 PM
  #28
jeb858's Avatar
Originally Posted by twuelfing
my vin is 0804 and my IMA system has all but stopped working when its warm out and or I have passengers in the vehicle. Honda will not even try to fix it. they say its normal for the IMA system to shut down all the time and gas milage to be below 35mpg.
i took delivery in october 2006
My question to Honda is "Why didn't it do this in the first 1 1/2 years of ownership".....
Old Jan 11, 2010 | 07:14 AM
  #29
drozzin's Avatar
What kind of scan tool did you use? Concerning DTC P15A5. It may be accompanied with DTC P0A3F, P0A5E, P0A5F, P0A61, P0A62, P0A64, P0A65, and/or P1440. The description is Motor Current Sensor Circuit Malfunction.
Old Jan 11, 2010 | 09:02 AM
  #30
jeb858's Avatar
Default Scan Tool and Code
I am using a Snap on Modus scan tool and I pulled a P0A7F "Battery Deterioration" and this was after the 09-058 update. The dealer performed two alleged new updates, 01-084 and 03-002.
The IMA light is gone, much less battery assist, and the IMA battery goes belly up just as quick.
