MY DIY HID headlight install
Old Nov 12, 2009 | 12:20 PM
  #131
navguy12's Avatar
Default Re: MY DIY HID headlight install
I really never noticed what the thread pitch was, I just got one out of my bench stock that fit. Honda has a universal bolt and nut standard, so just pull one off of something in the car, go to the hardware store (or to you honda parts counter) and say, "Give me some of these".
Check that. Much thanks.
Old Nov 18, 2009 | 12:56 PM
  #132
navguy12's Avatar
My unit arrived today and I have a few questions prior to beginning. I have re-read the original post.
My first question:
The instruction manual is telling me to drill a 25mm hole into the back cap
My second question:
The lamp comes with 2 sets of wires that don't seem to look like your set-up.
Also, the manual shows......
said second set of wires somehow being input into the headlamp unit.
I am assuming the following, please confirm:
That when I remove the original OEM bulb, the socket for same will now plug into the female connection on this ballast; and
2. MY DIY HID headlight install-img_9430.jpg.
Then, I connect the red (from ballast) to black (to bulb) and clear (from ballast) to red (to bulb).
The other wire shown here:
Click image for larger version
...is simply not used
If I sound totally confused by what should be a straight forward plug and play evolution, I am.
Your patience is greatly appreciated.
Signed: totally confused in Ontario
Old Nov 18, 2009 | 07:03 PM
  #133
So forget cutting a hole in your headlight housing. Then cut the grommet on the bulb wiring harness, and separate the 2 harnesses and discard the grommet.
Now go back and see if you can figure it out now.
Old Nov 19, 2009 | 03:52 AM
  #134
navguy12's Avatar
Yes, now that worked. I'm now online and they work perfectly!!!!!!
Much thanks.
Signed: unconfused in Ontario
Old Nov 21, 2009 | 08:38 AM
  #135
msk914's Avatar
I installed HIDs yesterday -- actually my trusted mechanic did, easier for him with his lift, etc -- and they are so much better than the original headlights. And they are low enough -- the car is low enough -- that they certainly seem to not be in people's faces as they drive towards me. When my mechanic was done and test drove it on some very dark roads, he said 'where do I get these for my wife's car, and what do they cost?' -- he was surprised at the approx $100 cost. He thought it would be much more.
Mark
09altimahybrid
21
Apr 8, 2010 05:07 AM
mikieboyblue
Apr 6, 2009 01:12 PM
Route66
Nov 21, 2007 01:15 PM
08Mariner
Sep 18, 2007 08:39 AM
littlekenneth
Oct 3, 2006 04:20 PM
