Engine Hesitation around 3000RPM - HCH II 2006
Old Aug 7, 2017 | 03:26 PM
Lukasz555's Avatar
Default Re: Engine Hesitation around 3000RPM - HCH II 2006
I think I have a similar problem During sudden acceleration. About 3000-3500 RPM, the car stops accelerating, and starts to work unevenly. I must then reduce to 2000-2500 RPM. To Let the car start accelerating again
half a year ago i replaced
12 v battery
engine fluid
Cvt fluid
P0171 error sometimes occurs
Old Aug 7, 2017 | 03:29 PM
Check oil level.
You might have a dirty MAF:
https://www.justanswer.com/honda/7d1...bank-lean.html
Furthermore, if you're having IMA battery issues, power can be horrible.
Old Aug 7, 2017 | 03:48 PM
Lukasz555's Avatar
Check oil level.
Oil level is ok. MAF sensor was cleaned
My battery is in poor condition But even when it is completely unloaded. At slower speeds (2500-3000) RPM the car slowly accelerates. And the engine works equally
HDS screen
Old Aug 7, 2017 | 08:50 PM
Looks like HDS has already given you the list to check.
Good luck,
Steve
pondscum
Mar 4, 2011 07:15 PM
tigertas32
Jun 19, 2009 05:36 AM
bwilson4web
Nov 23, 2008 10:21 AM
Tim A
10
Nov 30, 2007 07:05 AM
lion
Jul 23, 2005 10:53 PM
