"Brake System" light on
Old Aug 29, 2018 | 09:34 AM
Bigfoot100's Avatar
Default Re: "Brake System" light on
Sorry, do you mind explaining what "Blink Codes" means? Or point me to an explanation?
I talked to the dealer, and they told me there are no codes. Just the Brake System light. They insisted that if the check engine light is not on (which it is not), there are no codes to be read.
Btw, just to provide more details about the dealer recommendation: They recommended replacing the "brake master cylinder and service unit" for $4620 to address the Brake System light. Not sure what this means, and neither did the guy at the parts counter when I spoke to him. After doing some quick research, he figured the techs were probably recommending replacing the master cylinder as well as the full set of "servo modules." Obviously the car is not even worth $4620, so I'm looking for tips on how to diagnose the problem down to something specific.
Thanks!
Old Aug 29, 2018 | 11:48 AM
pasadena_commut's Avatar
On my car (different model than yours) short two of the pins on the OBDII connector and it enables a mode where various lights blink on the dash to show status codes. On some other models there is a service connector where pins will be shorted instead. You will have to determine which is right for your car. For a general idea, look at a video like this one:
You will need a list of codes for your car though.
No engine codes maybe.
I had a master cylinder replaced once. It cracked when the brakes were slammed on to avoid squishing a squirrel. It only cost a couple of hundred dollars to have it replaced. You might want to ask people you know for the name of a trusted independent repair shop and give them a try. It sounds like the dealer is just out to make the biggest $ possible off you.
Old Jan 16, 2023 | 09:59 AM
ItsdaSignGuy's Avatar
How did you fix the issue ?
noproblem07camry
Aug 26, 2020 03:00 PM
clk
Sep 19, 2019 03:35 PM
08hybridok
Sep 2, 2018 08:04 PM
sockmonkey75
Nov 21, 2008 01:36 PM
TankerGator
Jul 23, 2006 01:07 PM
