Did I cause my brake system problem?
Old Sep 17, 2019 | 09:15 AM
clk's Avatar
clk
Default Did I cause my brake system problem?
My 08 Escape Hybrid currently has ABS & BRAKE dash lights on along with "Check Brake System" msg. ForScan indicates four ABS codes (U2023-A0, C1478-A0, C1313-A0, C1480-E0), which, oddly, point to both right and left front wheels. Also seeing PCM codes P1A0C-FF (hybrid PCM - engine disabled) and U0418-FF.
This problem occurred immediately after carelessly tossing multiple heavy bags of cat litter into the rear cargo area. Any chance I messed up a connection to/from the high-voltage battery or something like that? If you think it's just a coincidence then I'll proceed with the usual suggestions posted elsewhere for resolving ABS problems (tone rings, grounds). Thanks.
Old Sep 19, 2019 | 03:35 PM
clk's Avatar
clk
Default Re: Did I cause my brake system problem?
Mechanic diagnosed as collapsed front brake lines. Replaced brake lines and reset ABS module. We'll see if the warning light stays off....
aigbokhaij
Toyota Highlander Hybrid
Dec 6, 2024 01:55 PM
08hybridok
Sep 2, 2018 08:04 PM
badplasma
May 7, 2014 02:23 PM
barry2557
Jul 10, 2012 10:17 AM
highlanderhybrid
May 14, 2007 12:02 PM
