Autostop
Old Jul 22, 2006 | 10:51 PM
nbalthaser's Avatar
Default Re: Autostop
Originally Posted by philmcneal
LAME! I"m hoping it would be like the toyota prius, use electricity until bat is low then gas engine ONLY COMES ON TO RECHARGE THE BATTTERY. Then shuts off again!
booo... at least you get regen while your idling... unlike my car ;(
question guys, if your battery is full (8 bars) and you decided to run the ac and say autostop in a parking lot for awhile. How long it would take to get the battery drained to the point where engine would come on?
and does your 12 volt outlet says "125 watt max?" there are two right?
well, the prius idleing to charge the battery is basically the same as what the hch.ii does. the only difference is that the prius can do it while in park while in the hch.ii you have to be autostopped. i encounted this the other day. while dropping a friend off, we were chatting a bit in the car with the a/c on and being powered by the battery. then the battery level dropped to about 1 bar and the engine kicked on to charge the battery. i had never seen this happen before and it was pretty cool.
at a full charge, the battery should be able to run the a/c for a good while, maybe 30 minutes or more. the electric motor on the a/c is pretty efficient.
there are 2 a/c outlets: one in the dash and one in the armrest and i'm not certain what the max wattages are.
Old Jul 23, 2006 | 08:49 PM
gumby's Avatar
Energy Independence
Yes, Neil. That happened to me Friday, too, while I was autostopped. For the first time. I know the SoC was at 2 bars. My guess is that it was about to go to 1 bar, and that's when the ICE started to allow forced charging of the hybrid battery. It was an odd feeling, but made sense. I think it's cool, also.
Old Aug 3, 2006 | 01:08 AM
philmcneal's Avatar
04 prius 350,000km
wow awesome 30 minutes for ac is plenty enough time to chill in the car if you have to wait for someone to pick up!!!
hm so when parking, what can one do to use ac without wasting too much gas? when pulling on the ebrake does that activiate autostop too?
fernando_g
Dec 20, 2005 10:18 PM
clayk
Dec 8, 2005 07:33 PM
lkewin
Oct 9, 2005 08:08 PM
merlin180
Jun 27, 2005 05:56 PM
arunster
Jun 21, 2005 04:44 AM
