Anyone with 06HCHII & Sirius?? or new tire??
Old Nov 29, 2006 | 10:18 PM
Anahymbrid's Avatar
Default Re: Anyone with 06HCHII & Sirius?? or new tire??
I'm still shocked and amazed... but now that there are TWO such cases, I guess I just have to start accepting that this is true!
There might be a cheaper alternative to replacing all the tires, though... you could buy one and get it cut... I believe the term is "siped"... to grind fresh rubber off the new tire until it equals the circumference of the other three. You'd have to judge if this is worth it based upon how much tire life you have on the other three.
Perhaps a cheaper alternative... if there's not too much wear on the old tires... is to raise tire pressure up on the old tires and reduce it on the new one. It might make just enough circumference difference to get the computer to accept that all wheels are rotating at the same speed.
I know I've said it before... but I'm STILL shocked!!! So does this mean that just going around a curve at high speed can cause engine RPM issues??? In a wide sweeping curve, the inside wheel would turn slower... that should be viewed by the computer the same as a smaller circumference tire. I'm still mystified!
Old Nov 29, 2006 | 11:01 PM
gumby's Avatar
Energy Independence
I'm with you Jeff. This seems just TOO sensitive!
I guess we'll all learn how to deal with this oddity better as time goes on and we have different situations arise.
Coal Miner
Mercury Mariner Hybrid
Aug 23, 2009 05:50 PM
08hybridok
Jun 12, 2007 08:55 AM
FL07THC
Feb 20, 2007 06:11 AM
rigger
Honda Insight
Dec 26, 2005 01:23 PM
