Trasmssion Fail at 97k
Old Jul 14, 2020 | 03:15 AM
Tahoe_08's Avatar
Default Re: Trasmssion Fail at 97k
yep aux pump is weak/ close to being dead... there goes a $1,000
Old Jul 31, 2020 | 12:46 AM
Tahoe_08's Avatar
I like to update
Fixed it with the New throttle body the car is throttle response is perfect now before I could not go above 2500-3,000RPMS
NOW when I FLOOR it 5,000 RPM!
this is pending further testing (obviously ) I tried to reproduce the issue i had. (it typically did it with the front A/C on only at 60F) with A/C on max with AUX A/C to add extra load on 60F it was 85F outside i went for about 15 miles at stop light after stop light and pulled over and did the brake test rapid stop and go (as this would trigger my issue of the engine revving , did not rev like that is park gear when pressing the brake and letting go) so we pretty much ruled out that it was the brake master cylinder internal leakage.......
a shop scammed me out of 360$ they claimed to fix it the issue with throttle by reprogramming/relearn random garbage i did not agree to (well i did do the 100,000 mile spark plugs /wires which i agreed to for 160 of that)
Old Aug 8, 2020 | 10:22 AM
dnt1010's Avatar
Might want to utilize the Hybrid specific diagnosis chart so that you pinpoint the codes meaning as intended.
File Type: pdf
jpezz
May 23, 2012 03:41 PM
idreamofspace
Sep 4, 2008 01:35 PM
bwilson4web
Dec 29, 2007 06:30 AM
Tim
Sep 9, 2006 08:48 PM
