Tire and rim swap between 2 camrys
Old Aug 20, 2008 | 07:40 PM
idreamofspace's Avatar
Question Tire and rim swap between 2 camrys
Hi guys, long time lurker, first time poster....
I have 2 Camrys. A 2007 THC and a 2008 SE. I'm travelling to Disneyland tommorow and I want to drive the Hybrid (of course!) but the tires are worn down to the tread wear indicator. My question is whether I can swap out the tires from my SE for the trip. I know the bolt pattern is the same, but I'm not sure about resetting the pressure sensors in the rims(I would still like to know if my tires are running low on air!).
Any insight would be greatly appreciated!
Old Aug 20, 2008 | 07:51 PM
rburt07's Avatar
Default Re: Tire and rim swap between 2 camrys
The TCH has a small button turned sideways just inside the glove compartment. It's on the left front side of the box with the door open. With the engine started try holding that button in for a few seconds. That should reset the cars tire sensor receiver to the new tire pressures.
All though don't know how the sensors work from one set of wheels, tires sensors to the other.
Old Aug 20, 2008 | 08:11 PM
Thanks for the info! I figured there was a reset button, but as you said, I'm curious whether the sensors are interchangeable between vehicles.
Guess theres one way to find out!
Old Aug 20, 2008 | 11:56 PM
rburt07's Avatar
Actually the reset button is used after you change your tire pressure up or down very much. If you have your rims/tires changed to the TCH at a tire shop, ask about about tire pressure senders.
Most tire shops have a instrument they use after rotation to change each sensor so it will read as a front tire and not a rear.
I have had my tires rotated on the TCH a few times and asked them not to use the sensor instrument. Their was about a $20 extra charge for that service. I don't know if the tire warning shows which tire might be low or not. It don't matter to me, if I see the yellow (!) come on I will sure pull to the shoulder.
Old Aug 21, 2008 | 12:41 AM
Just finished the swap in my garage with an impact wrench, torque wrench and a friend (only took about 20 min!). The indicator light did not come on after running the car for several minutes. Just to be sure, I took a 3 mile drive around the neighborhood and still no light. I'm assuming now that the sensors are universal (at least between like models). And I suspect the TPMS reciever on my car simply "assumed" the signal from the new rims and tires as I did not have to hit the reset button.
Anyway, it's off to Disneyland tommorow in the only TCH on the road with SE rims!
Old Aug 22, 2008 | 11:18 AM
flopshot's Avatar
What you did will not work.
The set of 4 TPMS is registered to a specific car's ECU. It takes a ECU programming tool to register different sensors to each car.
Just drive the car to Disneyland and your dashboard light will light up. Who cares! The sensor is just to give you an indication that you have a problem, so you just have to be more dilligent on making sure your tires are filled correctly before your trip.
Old Aug 23, 2008 | 11:45 AM
Intrus's Avatar
Professional Hacker
Which Disneyland did you go to? The one here in beautiful Sunny Southern California? or the other one in that retirement community they call florida?
Old Aug 23, 2008 | 08:36 PM
habu968's Avatar
Any pics with the SE wheels?
Old Sep 4, 2008 | 01:35 PM
Fooshe's Avatar
That is 100% corrrect. The new sensors will not be recognized by the ECU until the ECU is synch'd with the new sensors. After enough miles, your light will go on to let you know the ECU is not recognizing the sensors.
bmgoodman
Nov 30, 2013 12:14 PM
Realization
May 21, 2012 12:15 PM
spud
Dec 31, 2006 05:17 PM
TCHandler
Jun 19, 2006 12:42 PM
stevenvillatoro
May 1, 2006 09:27 PM
