Remote Start Failure
![Unhappy](https://electricvehicleforums.com/forums/images/icons/icon9.gif)
Recently when I have been using my expanded key fob to start my Chev Tahoe I noticed that the 10 min timer would not display on the key fob. I also noticed that the display would flash and the vehicle would not remote start. The dealer corrected this problem by replacing the key fob and reprogramming it.
![Shade](https://electricvehicleforums.com/forums/images/smilies/emotikons/shade.gif)
Sounds like your remote is nicer than my remote. I just have the three buttons (plus red button) remote start key fob. No problems with mine though. I remote start everyday to make sure the A/C cools her off before I get in.
Hi Fjungman, I guess mine is some kind of extended range unit with a screen display of the vehicale. The screen can display time, milage, fuel level, tire pressure, remote start time counter, turn on the radio, and display the time. It has a 1/2" antenna on it and is a little bulky. There is also an antenna in the left hand side rear window.
I have noticed with my advanced remote start that when I try to start the vehicle sometimes after having used it once it will not start. I think that I have read somewhere that if you push a certain button again you can extend the remote start from 10mins to 20 mins. Any ideas? I will read the owners manual agian and remote start book and see if I can find anything.
So yours does display the current time? I swore when I first had mine it showed the time, but hasn't for the last year. It will show time remaining on auto start, and the rest of the options you described (fuel level, tire PSI, milage).
Thanks Jet 1 for your help, T-Pole mine does display the time when synced to the Nav Display. You have to go to the time page on the Nav Display to sync it and hold one of the three buttons.
