Please review my battery pack data
Old May 5, 2017 | 10:53 PM
XOnanoSmartfoam's Avatar
Default Re: Please review my battery pack data
Originally Posted by Jaime
I have a bluetooth OBDLinkMX device that I plug into the OBD2 port and I used software called ScanXL on my PC and the Torque app on Android to get the voltages.
In Torque you can request the following PIDs:
Battery Module#, PID
1, 2240E4
2, 2240E5
3, 2240E6
4, 22410B
5, 22410C
6, 22410D
7, 2240F0
8, 2240F1
9, 2240F2
10, 2240F3
11, 2240F4
12, 2240F5
13, 2240F6
14, 2240F7
15, 2240F8
16, 2240F9
17, 2240FA
18, 2240FB
19, 2240FC
20, 2240FD
Divide the returned value of each by 10 to get the voltage. The formula you enter in Torque is "A/10" for the voltages.
The State of charge is at PID 222411. The formula is "(A*100/255)"
The battery pack current PID is 2240D2. The formula I used is "((signed(A)*256)+B)/20)". I'm not 100% sure this is accurate but it shows you when it is charging and discharging which matches when the voltages go up and down.
Thank you so very much, it worked like a champ and I am now logging my battery voltages as well as the charge state. I will see if I can find any anomalies and hopefully fix them.
Old May 6, 2017 | 06:34 AM
Up to about 50A, you should not have a deviation larger than 0.2V between the highest and lowest block voltage. 0.3V may be workable, but it's indicative of an ailing pack.
Under heavy loads, 80A+, deviations of up to 0.6V seem pretty common, but they are usually transient and will slip back to the 0.2-0.3V range IF your pack is in good shape.
If you see blocks that are outliers on the order of 1V, you have a failed cell in that block.
If you see a block swinging from being the high voltage one during charge to the low voltage one during discharge - failed cell.
Good luck.
Old Jul 18, 2017 | 04:28 PM
dawgfan1606's Avatar
Thanks for providing the PIDs!! I've been having issues with stalling at stop signs and at times the RPMs just reving up when I come out of AutoStop - usually happens when I am within the first 5-10 minutes of first driving (hot inside). I had vacuumed my HV battery vents (a few months) ago, but didn't realize the spot Hillbilly (and others) mention is located on the actual battery. I pulled the cover, last night, and it looked like a dryer vent after a load of towels.
Now, that I have the PIDs, I have been monitoring my performance today. It was about 90*, but I never had an issue. So, I have my finger's crossed it was due to a lack of air getting into the battery.
However, I noticed my SoC was about 50 and throughout my stop and go driving it varied from 49 to 65, but the last few miles to my house it got up to 70. My banks all stayed within .3 of each other and ranged from about 17.5 down to the high 14s, but stayed in the 17 range the majority of the time..
My question, does the SoC ever get up to 100%? My Tahoe was still going into AutoStop no matter the SoC.
1, 2240E4
2, 2240E5
3, 2240E6
4, 22410B
5, 22410C
6, 22410D
7, 2240F0
8, 2240F1
9, 2240F2
10, 2240F3
11, 2240F4
12, 2240F5
13, 2240F6
14, 2240F7
15, 2240F8
16, 2240F9
17, 2240FA
18, 2240FB
19, 2240FC
20, 2240FD
Old Jul 18, 2017 | 05:20 PM
The SoC should never be 100% unless there's a malfunction.
Given that this is a Toyota built battery, it's likely the SoC range is 40-80% with a "resting" SoC of 60%.
rperla
Jul 24, 2019 03:20 PM
jeffemcguire
Aug 10, 2016 08:26 PM
joystix2
May 15, 2007 12:30 PM
weyus
Sep 9, 2006 04:56 PM
