P0C17 and P0C18 Tahoe Hybrid 2008
Old Jun 14, 2019 | 04:35 PM
  #41
Chicago38's Avatar
Default Re: P0C17 and P0C18 Tahoe Hybrid 2008
Originally Posted by Jaime
Keep on troubleshooting.
Found the following:
#PIT4820A: (hybrid) Service Power Steering Message With DTC C0895 - keywords 2-mode battery code electric hp2 indicator low mode module power PSCM two-mode voltage 2 - (Feb 16, 2011)
Condition/Concern:
You may experience a "Service Hybrid Message" on the Drivers Information Center (DIC) followed by a DTC C0895 set in the Power Steering Control Module (PSCM).
Recommendation/Instructions:
If you experience this message, please check all other module for diagnostic codes before addressing the C0895 DTC. Most likely the code was set due to a hybrid related concern that caused the 300 volt hybrid battery contactors to open which in return will set a C0895 code in the PSCM.
Clear the codes with your tool, and then also try disconnecting the 12V battery for some time.
I try everything. I think my problem in APM module because when I try reading APM module my scanner freezing.
Where APM module location?
Old Jun 14, 2019 | 06:53 PM
  #42
Tahoe_08's Avatar
Originally Posted by Chicago38
Hello. I have Tahoe Hybrid 2008 car not started.We install new 12v battery but car still not started.
I have 2 trouble code:
P0C17 Drive motor A position sensor not learned
P0C18 Drive motor B position sensor not learned
Any body help me please.
tech2 maybe
Old Jun 14, 2019 | 06:57 PM
  #43
Chicago38's Avatar
Originally Posted by Tahoe_08
you screwed up you need to use one of those "remember" settings things before swapping the battery
What do you mean?
Old Jun 14, 2019 | 08:42 PM
  #44
Jaime's Avatar
The Accessory Power Module is the component stacked at the bottom of the assembly under the plastic cover on the passenger side of the engine compartment. It is under the Power Inverter Module (PIM) assembly.
I would recommend scanning other modules first to see if you can read the 42V from the APM since it is pricey (ranges from $400 to $800.) Inspect the wires and connectors going to the APM.
Old Jun 15, 2019 | 04:25 PM
  #45
Chicago38's Avatar
Just video what is going on after turn key
Old Jun 18, 2019 | 07:23 PM
  #46
Chicago38's Avatar
11 years have passed since Tahoe started selling but there are no solutions to many problems. Dealers are incompetent in solving the problems of hybrid cars, all they can say is replacing the battery or transmission. Great desire to repair the car but hands are already falling!
Old Apr 18, 2020 | 06:32 PM
  #47
Chicago38's Avatar
Hello everyone. My loong history done! We bought used transmission and replaced. After that my tahoe start and running good.
Jaime
13
Jul 18, 2017 05:20 PM
volt
Apr 26, 2017 05:05 PM
bikenkite
13
May 13, 2016 04:52 PM
