2009 Chevy Tahoe Hybrid P0BBD
Old Apr 24, 2017 | 09:32 PM
volt's Avatar
Default 2009 Chevy Tahoe Hybrid P0BBD
Good Day Members.
Trying to find the problem . Has 161k miles. In live data voltage could be 14.5 then 18.5-19.0v across all 20 batteries. Would Motor 1 Generator cause over voltage or Defective battery.?
tnx
Old Apr 24, 2017 | 10:34 PM
Jaime's Avatar
Default Re: 2009 Chevy Tahoe Hybrid P0BBD
Check out the data logs I created from my family's Tahoe Hybrid with a bad battery:
https://www.greenhybrid.com/forums/f...ck-data-31149/
If you are able to capture all the 20 voltages of the battery pack modules, you'll be able to calculate the difference between the highest and lowest voltages at any given time. As you can see in my captured data, the voltage difference often exceeded 1V and even reached 3V a few times.
Old Apr 26, 2017 | 05:05 PM
volt's Avatar
Good day Members.
At parking with ignition on voltage difference between battery cells would be no more than 1.5v, lowest 13v highest 14.5v. when driving voltage difference would stay the same , but voltage would go up to 19v . and main voltage would fluctuate from 270-390v
Volquinum
50
Nov 17, 2018 04:49 AM
Selecta82
Nov 20, 2015 07:08 AM
H-Bomb9000
Mar 7, 2015 09:33 AM
Canuck
Aug 29, 2011 07:29 PM
Eskrimast1
Jan 9, 2006 09:53 AM
