New hybrid battery
Old Jan 29, 2020 | 10:47 AM
BamaPaul's Avatar
Default New hybrid battery
Today I called the three local GM dealerships to get a price on the battery. I was told 84442216 is no longer the correct part number for the unit. It has been changed to 84629371 and the warehouse doesn't have stock, doesn't show a price, and doesn't have a date as to when they would have it in stock. I wanted to at least get a good price check on this thing and weigh my options of rebuilding the pack, buying a used pack, or getting a new pack that I can put another 200k miles on.
I called GM customer service and asked them for any information on availability and after a 25 minute hold, I was told they would get back to me in two days. Just frustrated with the support that GM put into these trucks. This system could have done more to lower fuel consumption in the US than the tiny hybrids out there ever would.
Old Jan 29, 2020 | 02:07 PM
Tahoe_08's Avatar
Default Re: New hybrid battery
Some Aero issues could have been fixed bet they did not bother because of patent issues
the under belly is a mess esp the rear muffler
Old Jan 30, 2020 | 03:39 PM
BamaPaul's Avatar
Just got off the phone with GM customer service and was told that GM has discontinued the battery and that they do not have to keep parts available for vehicles over 10 years of age. They did however tell me there was a new old stock battery in Atlanta.
Old Jan 30, 2020 | 04:54 PM
Given that they use the same battery as the 2012MY, they're full of ****. They're still required to keep parts available for that MY.
If it's truly NOS that's been sitting for years, pass unless they give you a huge discount. If it's less than a year old based on the SN of the modules, it's probably fine.
Old Jan 30, 2020 | 05:13 PM
BamaPaul's Avatar
Thanks for the advice.
Old Jan 30, 2020 | 05:57 PM
BamaPaul's Avatar
S Keith what's the best way to check milliamps of used units? I will be going that direction of the battery in Atlanta is old/overpriced
Old Jan 30, 2020 | 06:14 PM
Buy two 2016+ Prius C units with less than 30K miles. Period. Check voltages. Each pack will be within 0.02V and they should be within 0.05 between packs. Build. Done.
If you want to literally add 60-80 hours of laborious/tedious testing, then I'll entertain the question, but I'd really rather not.
Better to build the battery and do a Torque test.
Old Jan 30, 2020 | 08:14 PM
Tahoe_08's Avatar
they built them to 2013 model year was the last year that means WARRANTY for California models will be tell 2024(assuming one was bought in 2014 ) (unless GM directed the dealers to punch the warranty on 12/31/2013)
that means they will still need to keep some on hand tell 2025 or 26( if someone buys a new stand alone battery in 2023).
Tell them you live in a C.A.R.B.state
tell you got a 2013 and you need a new battery it has 200,000 miles on it and you demand to buy a new battery for your 7 year old SUV be sure to have a vin on hand might need it
tell them you have smog testing and you have check engine light for new battery and it failed smog test(more then likely they will not check that) other wise you will file a complaint with CARB and federal
1GNSCDEJ6DR194938; 1GNSCDEJ5DR121110 are random 2013 hybrid vins
drmarvin
13
Apr 16, 2018 09:41 PM
drmarvin
Jan 19, 2018 05:48 AM
jimr5454
Apr 8, 2014 11:17 AM
cdbrow1
Jan 5, 2013 10:41 PM
kklein
Jan 31, 2010 05:47 PM
