installing a power Inverter ?
Old Apr 14, 2014 | 05:07 AM
jimr5454's Avatar
Default installing a power Inverter ?
I am going to need to install a larger power Inverter in a 08 yukon hybrid I know it has a small one factory installed but that will not be big enough I need a 1200 watt inverter to run a occasional too .not everyday all day but I need the power when it is needed.any suggestions?And I'm not a teenager but I will want to install a small amp to power a 8 Inch Sub Somewhere In The Truck .My Lights Would Dim Just A Hair In My Jeep When I Was Jamming To The Beatles Or The Dave Matthews Band Any Words Of Advice On The Instalation ? I know the truck might be sensitive to anything electrical so where might I get the power to run the above so it won't interfere with anything ????
Thank you in advance...
Jim
Old Apr 14, 2014 | 05:45 AM
Did you get it? Post pics?
Old Apr 14, 2014 | 06:50 AM
jimr5454's Avatar
Default Re: installing a power Inverter ?
Going in today at 4pm... nervous put allot of thought into it .not liking all the miles on it and mostly resale value but I can't find many to compare actual sold for so I'm hoping $18,750 is a good deal at 112000 miles .I thought I would ask those lay questions before I go get it. Anybody have any ideas on installing the inverter and sub amp? Ty ..
Old Apr 14, 2014 | 06:52 AM
jimr5454's Avatar
This is a GREAT forum...
Old Apr 14, 2014 | 07:52 AM
As I recall adding extra power drain is not advisable on the hybrid. If a source is need for extra accessories, I think there is a specific 12V source in the driver side fuse block. That is where I sourced my radar detector. But adding subs and diodes will put a lot of drain on the battery. The 300V hybrid battery is not something you want to replace regularly like 12 V one.
Old Apr 17, 2014 | 04:03 AM
jimr5454's Avatar
How would I find the right right way to install a more powerful inverter? Where is the factory power Inverter that's in the back?
Old Apr 17, 2014 | 05:12 AM
In my escalade, it is at the driver side rear.
Old Apr 17, 2014 | 11:26 AM
Hillbilly_Hybrid's Avatar
yes driver's side rear on SUV. 150 Watts.
Motown
General EV Discussion
17
Jul 21, 2016 03:09 AM
lars-ss
Off Topic
Jan 24, 2010 07:48 PM
hondaguy
May 27, 2005 07:15 PM
