High Voltage Battery Replacement, Vehicle wont start.
Old Feb 15, 2022 | 09:30 AM
Default Re: High Voltage Battery Replacement, Vehicle wont start.
Blue circle is the isolated side of the relay.
arrows pointing to terminals.
Old Feb 15, 2022 | 09:39 AM
Parker's Avatar
my bad, i ment to circle the end of the relay that connected to the battery.
Old Feb 15, 2022 | 11:16 AM
Parker's Avatar
no voltage from either terminal to the case, neither solenoid/relay is stuck closed.
Old Feb 15, 2022 | 11:30 AM
On a Toyota (this battery is made by Toyota), this would essentially eliminate the chance that the hybrid battery is the source of the HV isolation fault unless it's the battery computer itself.
Old Feb 15, 2022 | 11:46 AM
Parker's Avatar
I've changed the computer as well, so I doubt that's the cause.
Ptaylor85
Oct 2, 2019 05:43 AM
stotta87
Dec 27, 2016 11:24 AM
waltwalt
Nov 29, 2015 06:42 PM
