my volt app on chevy tahoe?
Old Feb 16, 2022 | 04:56 PM
Tahoe_08's Avatar
Default my volt app on chevy tahoe?
does the my volt app work on the Tahoe hybrid? I want to turn off the engine while coasting to a stop....
Old Feb 16, 2022 | 07:09 PM
Jaime's Avatar
Default Re: my volt app on chevy tahoe?
The Tahoe already does that
Old Feb 16, 2022 | 07:21 PM
Tahoe_08's Avatar
i want to turn it off at 70-80mph(coasting down hill) while coasting to a stop the max speed of auto stop is 30mph also I want my shift lever to last longer.... Because i PRE start the engine going to m4 before I leave a traffic light (just in case)
Old Feb 16, 2022 | 07:27 PM
Jaime's Avatar
Fuel is already cut off when you're coasting. That's how it provides engine braking. The Tahoe is already smart enough to not waste gas when it doesn't need to keep the engine running.
Old Feb 16, 2022 | 09:57 PM
Tahoe_08's Avatar
it still uses some gas :/ I see the fuel air mixture (data from the o2 sensors ) maybe i need to replace them? i think one sensor is slow and possibly a second sensor
Old Feb 17, 2022 | 12:00 AM
Jaime's Avatar
Straight from the service manual:
"Deceleration Mode
When the driver releases the accelerator pedal, air flow into the engine is reduced. The ECM monitors the
corresponding changes in the TP, the MAP, and the MAF. The ECM shuts OFF fuel completely if the
deceleration is very rapid, or for long periods, such as long, closed-throttle coast-down.
The fuel shuts OFF in
order to prevent damage to the catalytic converters."
If your Tahoe is not doing all that, it may be due to the AFM disable device you've posted about in the past.
Old Feb 17, 2022 | 12:24 AM
Tahoe_08's Avatar
"Deceleration Mode
so if the O2 sensor is reading something it's in error, i have an abnormally high positive fuel trims 10-12 as well i'm sure it explains why the mpg might be inconsistent
Old Feb 17, 2022 | 12:31 AM
Tahoe_08's Avatar
My o2 sensors are showing false data i think my fuel trims are positive 10-12 so it's running lean most of the time ("add fuel")
i tired adding a small restriction but it went far negative fuel trims and ran rough -10 to -12
Old Feb 18, 2022 | 05:44 AM
SonomaGTLS6's Avatar
I wouldn't be worried with trims at 10-12 (especially if you are in a cold region of the world right now)...depending on the temperature outside your truck will trim +/- 25% without throwing a code. Before you go too crazy with programming, might be worth just changing out the front O2 sensors.
Old Feb 19, 2022 | 01:31 AM
Tahoe_08's Avatar
it's year around even in the summer time it would go upto positive 29 the O2 sensor is slow to respond after a DFCO event which the sensor will slowly creep up from 0.00
martinjlm
General EV Discussion
Apr 23, 2007 05:45 PM
bwilson4web
Mar 22, 2007 02:04 PM
Neil
Feb 7, 2007 12:16 PM
turk
16
Jan 12, 2007 01:16 PM
