Can I Disable AFM?
Old Nov 9, 2017 | 03:28 PM
tiktok4321's Avatar
Default Can I Disable AFM?
Since the major engine work I've recently endured, I've been wondering about disabling the Active Fuel Management system - a VERY popular action by 08-09 5.3, 6.0, 6.2L owners. Anyone know if this would affect the hybrid system?
Old Nov 9, 2017 | 03:34 PM
tiktok4321's Avatar
Default Re: Can I Disable AFM?
Obviously mine was not a bad injector. It was another stuck lifter. I spent another $1600 to replace the cam shaft and all the lifters again.
I'm afraid if you have a stuck lifter, you may have worn cam lobes. And there is also a plastic tray that the lifters sit in that tends to crack, causing the lifters to spin around and get stuck.
How did yours turn out?
Old Nov 16, 2017 | 09:37 AM
Hillbilly_Hybrid's Avatar
There is a 5-Way plug way in the back of the engine not too far from oil pressure sender. If you un-plug it. No AFM. There will be codes and a CEL.
If Auto-Stop is disabled, it affected the Hybrid.
Old Jul 8, 2019 | 09:19 PM
Andrew Lefebvre's Avatar
What about using the RANGE TECH. after deleting VLOM and new ls7 lifters? Will it throw codes?
Old May 2, 2021 | 08:01 PM
POS-Yukon-Hybrid's Avatar
Ok i have a question I have a 08 Yukon hybrid i did a dod afm delete i put a stock vvt cam non dod ls7 lifters and freshened up the motor i have nothing but issue cant keep it running no matter what i try have anyone done this ?
Old May 7, 2021 | 03:13 AM
Tahoe_08's Avatar
you used the wrong parts the only choice with the hybrid is to use the stock parts,,,
unless you can find someone to tune it
Range does disable the AFM but does not disable codes...
Old Oct 27, 2021 | 02:31 PM
Rusty E Good's Avatar
Summit racing sells afm delete kit, headers , tuners cams etc….. for our shity *** hybrids. Just had 2nd valve collapsed in 10000 miles. Same valve both times. I’m gonna by the delete kit get different heads and a Diablo 13 tuner. Hoping that will fix my dropping valve issue , my bogus no oil pressure issue I’ve gotten randomly or by weekly for last 5 yrs and the doggy acceleration from 0-60 them kicks in like a turbo issues truck only gets 14-16 mpg in the 6 yrs I e had it. Wasted my money on this thing. May as well Hd some performance to it.
on all cylinders in summit site they list all the stuff you can do that doneheads on here say can’t be done.
Old Nov 13, 2021 | 01:37 PM
Tahoe_08's Avatar
The range device works with the hybrid it does not disable AS though ( disconnect the hood sensor for that)
cncguy2000
15
Oct 22, 2019 09:38 PM
BamaPaul
Sep 21, 2017 05:35 PM
Club3kgt
Sep 10, 2015 09:15 PM
Dslade05
10
Feb 9, 2014 06:30 PM
Dslade05
Apr 17, 2013 07:27 PM
