08 Tahoe Hybrid Battery
Old Jun 3, 2019 | 01:04 PM
nfuller's Avatar
Default Re: 08 Tahoe Hybrid Battery
After a thorough inspection, I did not have the main connector shown in the picture above plugged in correctly. I fiddled around with it and got it all plugged in correctly, and all codes were resolved.
Thanks for all the advise troubleshooting this silly issue. It finally runs and drives great again!
Old Jun 3, 2019 | 07:11 PM
Originally Posted by nfuller
I am in San Diego, CA.
I got my batteries from https://www.electronautomotive.com/
I will double check the torque on all of the terminal nuts while I am looking at connector plugs.
You didn't indicate if you had checked the torque on the terminal nuts. It is critically important that they be 48 in-lb. Too loose, and they will produce way more heat than they should. It will contribute to premature failure. Improper installation will likely void your warranty, and now there is a public record thereof.
Jeremy Hebel
Mar 5, 2022 03:11 PM
bikenkite
13
May 13, 2016 04:52 PM
David Ojeda
Oct 6, 2015 11:55 PM
Mauricio28
Nov 3, 2010 01:17 PM
grnhybrid
Oct 29, 2007 08:39 AM
