08 Tahoe Hybrid Battery
Old May 28, 2019 | 10:18 AM
dirt657's Avatar
Default Re: 08 Tahoe Hybrid Battery
Nope. Unless by "middle" you mean the middle 38 and probably one of the ends, then yes. The 0.5V difference between the first two blocks is also indicative of failure/weakness.
Time for a new battery.
Is there anyway I could PM you for a quick chat about a Yukon battery im working on?
Old May 29, 2019 | 01:15 PM
nfuller's Avatar
I just replaced the batteries in my 2010 Tahoe Hybrid and now getting a ton of codes I cannot clear. These codes have locked out an engine start, so I am stuck. I was told I need to follow #PIT4808H, but I am having trouble determining if my OBDLink MX+ can perform the SEQ EBCM/HCP/ECM/TCM/BECM Sequential Programming called out. Below is a list of all the codes that I cannot clear. Any help is greatly appreciated!
HPCM-HybridPtCtrl ($7E1) U1888 Network Confirmed Manufacturer Defined
ECM-EngineControl ($7E0) P0AC4 PowerTrain Confirmed Manufacturer Defined
ECM-EngineControl ($7E0) P0AC4 PowerTrain Pending Manufacturer Defined
ECM-EngineControl ($7E0) U0109 Network Pending Lost Communication With Fuel Pump Control Module
ECM-EngineControl ($7E0) U0129 Network Pending Lost Communication With Brake System Control Module
HPCM-HybridPtCtrl ($7E1) U1875 Network Pending Manufacturer Defined
HPCM-HybridPtCtrl ($7E1) U1878 Network Pending Manufacturer Defined
HPCM-HybridPtCtrl ($7E1) U1888 Network Pending Manufacturer Defined
HPCM-HybridPtCtrl ($7E1) P0BBD PowerTrain Permanent Manufacturer Defined
HPCM-HybridPtCtrl ($7E1) U1888 Network Permanent Manufacturer Defined
HPCM-HybridPtCtrl ($7E1) U1875 Network Permanent Manufacturer Defined
HPCM-HybridPtCtrl ($7E1) U1878 Network Permanent Manufacturer Defined
ECM-EngineControl ($7E0) U0109 Network Permanent Lost Communication With Fuel Pump Control Module
ECM-EngineControl ($7E0) U0129 Network Permanent Lost Communication With Brake System Control Module
Old May 29, 2019 | 02:03 PM
No. Make a thread.
Bad 12V battery.
Old May 29, 2019 | 02:19 PM
nfuller's Avatar
I had the 12V battery disconnected during the hybrid batter change. I will try replacing the 12V battery tonight and see if the codes clear this time.
Old May 30, 2019 | 05:12 PM
nfuller's Avatar
No. Make a thread.
Bad 12V battery.
I just had the battery checked, and there were no issues found with the 12V battery. I still have all these codes.
ECM-EngineControl ($7E0)P0AC4PowerTrainConfirmedManufacturer Defined
HPCM-HybridPtCtrl ($7E1)U1888NetworkConfirmedManufacturer Defined
ECM-EngineControl ($7E0)P0AC4PowerTrainPendingManufacturer Defined
ECM-EngineControl ($7E0)U0109NetworkPendingLost Communication With Fuel Pump Control Module
ECM-EngineControl ($7E0)U0129NetworkPendingLost Communication With Brake System Control Module
HPCM-HybridPtCtrl ($7E1)U1875NetworkPendingManufacturer Defined
HPCM-HybridPtCtrl ($7E1)U1878NetworkPendingManufacturer Defined
HPCM-HybridPtCtrl ($7E1)U1888NetworkPendingManufacturer Defined
ECM-EngineControl ($7E0)U0109NetworkPermanentLost Communication With Fuel Pump Control Module
ECM-EngineControl ($7E0)U0129NetworkPermanentLost Communication With Brake System Control Module
HPCM-HybridPtCtrl ($7E1)P0BBDPowerTrainPermanentManufacturer Defined
HPCM-HybridPtCtrl ($7E1)U1888NetworkPermanentManufacturer Defined
HPCM-HybridPtCtrl ($7E1)U1875NetworkPermanentManufacturer Defined
HPCM-HybridPtCtrl ($7E1)U1878NetworkPermanentManufacturer Defined
Old May 30, 2019 | 05:32 PM
The scope of systems covered by those codes screams 12V battery.
  • Bad battery connection
  • Bad main leads
  • HV battery safety plug not inserted correctly (not locked in place - 3 steps - 1) insert, 2) lever it up vertically, 3) slide it down to lock) - but this should have its own code.
  • You did something horribly, horribly wrong during the installation and broke stuff.
Old May 30, 2019 | 09:02 PM
Jaime's Avatar
U1888 Lost Communication with Battery Pack
U0109 Lost Communication With Fuel Pump Control Module
U0129 Lost Communication With Brake System Control Module
U1875 Drive Motor A Control Module Lost Communication With Battery Energy Control Module
U1878 Drive Motor B Control Module Lost Communication With Battery Energy Control Module
P0BBD Battery Pack Variation High
P0AC4 Powertrain Control Module Requested MIL Illumination
The Electronic Brake Control Module and Fuel pump Control Module are both at one end of the high speed bus after the Battery Energy Control Module. My guess is that you did not plug in the multi-wire harness connector at the battery all the way in. If that happens, it will disconnect the battery, fuel pump, and brake system modules from the rest of the bus. That would account for the first 5 codes above.
For the P0AC4 code, that was set by the PCM to alert you of a problem by turning on the "check engine" light.
For the P0BBD code, it must be left over from before you replaced the battery. It is still stored in the Hybrid Powertrain Control Module. Since it has not been able to communicate with the battery module, it does not know that it is good now.
If you still have problems after verifying the connector is all the way in, I would suspect that the battery energy control module inside the high voltage battery has problems. Did you install a new or used/rebuilt battery? It could also be that the harness going to the module was not connected properly if it is a used/rebuilt battery.
Old May 31, 2019 | 08:57 AM
nfuller's Avatar
After thinking thru everything I did during the battery change, I am thinking I did not get some of the connectors together properly. I had quite a bit of trouble getting the main connector back together. I didn't want to force it and break something. It just didn't feel like it would click in place. I will go back thru and check all my connectors and double check the safety plug and voltages.
FYI
I removed the individual batteries and installed new batteries. Which by the way is a lot more tiny bolts than I found in any online descriptions or videos, but still not that hard overall.
Thanks for all the suggestions guys. I will update after I have double checked everything.
Old May 31, 2019 | 10:14 AM
You need to go back several steps.
Are you in Oklahoma?
Did you replace the modules with the sh!tty Chinese modules? If so, don't expect them to last. I purchased and evaluated 5 of these (state that you're going to test them, and it ensures you get the cream of the crop), and MOST 10+ year old Gen2 Prius modules are better. They use some dirty tricks to make their modules appear very good when new, but they deteriorate VERY rapidly.
Second, regardless of what you used, did you torque all 80 terminal nuts to 48 in-lb? If not, you need to do it. Too loose, and you'll get high resistance, heat, voltage drop and likely block deviation error codes. Too tight, and you risk snapping off the terminal stud. I don't remember how the main connections are made to the relays, but if they're nuts on studs, same thing applies. If they are 8mm hex head/5mm thread, it's 48 in-lb. If they are 10mm hex head/6mm thread, it's 60 in-lb.
If you don't have a quality torque wrench that can reliably produce those torques, get one.
Old May 31, 2019 | 01:40 PM
nfuller's Avatar
I am in San Diego, CA.
I got my batteries from https://www.electronautomotive.com/
I will double check the torque on all of the terminal nuts while I am looking at connector plugs.
