Variable Valve timing
Old Jun 28, 2004 | 09:22 PM
Hot_Georgia_2004's Avatar
Well I admit not being as technically knowlagable as you all are, but I do see what seems to be a possible improvement on the HCH CVT.
I've noticed while coasting but not to the point of charging, I am dragging along all the mechanics of the engine: Steveo you mentioned copper to the sleeve, also bushings & bearings turning etc.
Shutting down 3 of the 4 cylinders are great but in this conditon why not shut all 4 down and disconnect ICE completely? Just like a disconnected MT clutch plate? IMA could still spin for the charging if the foot is backed further off.
All this dead engine friction needlessly wastes kinetic energy and MPG.
I'll occasionally get around this by shifting into neutral. Wish I could back off the foot feed to a point and get the same results as a disconnected clutch plate.
I know Steveo and Wayne were talking about valves, timing & such but I was wondering your take on this.
Old Jun 29, 2004 | 03:44 PM
Stevo12886's Avatar
Steve,
How interesting, i was just thinking about that during a little debate wether the IMA was really a hybrid. For the second gen. of the IMA having a clutch between the IMA and crank (think like normal trans but backwards sense IMA motor is used as flywheel). Not only would it improve the regeneration...but the IMA could be used as the sole power source during stop and go traffic. The system would increase weight a little so it wouldnt be quite as quick and a little more inefficient...but a stealth mode would be possible so it would really be void.
Cheers,
Steven
Old Jun 30, 2004 | 06:33 AM
flare's Avatar
Originally posted by Stevo12886@Jun 20th 2004 @ 8:29 PM
and Mazda has recently come up with (or was it Mitsubishi?) a three stage cam lift and duration...
i think Mitsubishi...look at the lancer ralliart
Old Jun 30, 2004 | 04:23 PM
Stevo12886's Avatar
Flare,
Was just reading through my Car and Driver s and it is Mitsubishi...its called MVEC.
Cheers,
Steven
cbxtc6
Sep 15, 2014 12:54 PM
davidb
Jan 2, 2009 03:12 PM
toast64
Apr 1, 2006 09:16 PM
tanstaafl14
Website Questions & Input
Sep 9, 2005 09:27 AM
