Learning on my Second Tank
Old Jul 28, 2006 | 12:05 PM
VaBeachPrius's Avatar
Default Learning on my Second Tank
Who says rookies can't get lucky?
Old Jul 28, 2006 | 12:33 PM
bwilson4web's Avatar
Engineering first
Thumbs up Re: Learning on my Second Tank
Well done! Your signature block will update within the hour.
A minor suggestion but see if you can minimize the 'regen'. Although 'regen' is better than the alternative, conservation of momentum is best.
Bob Wilson
Old Jul 28, 2006 | 01:11 PM
Default Re: Learning on my Second Tank
Agreed on the regen. I was on slightly unfamiliar roads and there was a lot of traffic on my backside (at the speed limit, mind you).
Earlier in the week, I was near my house driving a loop where I could glide more and I was averaging in the low 90's mpg wise. The car is pretty amazing. I am doing better (MPG's) by judiciously using stealth and gliding more. It seems to make the pulse mpg's better, which in turn means I don't have to glide as far for good mpg. If I get the HV SOC high enough, I can cruise at about 45 mph while seeing between 60-80 mpg on the display. Too bad that road isn't long enough to keep it up for long, thus back to the pulse and glide between lights.
I have to travel the month of August and some of september so I might be able to squeeze in a 70+ mpg tank then with what I think I have learned from a thread on this site by the marathon miler's (sp?). Hopefully, September will be a warm month.
Thanks,
Chris
Old Jul 29, 2006 | 09:06 PM
bookman's Avatar
We took our new TCH out for a fun drive. The route was ~230 miles under ideal conditions (relatively flat open local roads, 50-60 MPH cruising speed, only 2 to 3 lights in each direction. I was extremely pleased with the TCH performance, ~42 MPG. Not bad when you consider we were not using any special techniques.
Old Jul 30, 2006 | 04:51 AM
Good job, Bookman. This tank must have been a fluke. I found out what having four people in the car, heavy use of AC, and short trips does to gas mileage.
I will have to wait until September to find out. I will be out of town for the next 45 days. No family, no prius.
Chris
yu888
Oct 3, 2010 09:25 AM
stephen431
28
Sep 15, 2008 05:29 AM
Tim K
Dec 20, 2006 04:04 PM
EricC698
Jul 23, 2005 12:05 AM
