Ford Motor Company Ford, Mazda and Mercury hybrids
What parts should I replaced after buying used?
Old Aug 15, 2019 | 12:22 PM
iamtokebi's Avatar
Default What parts should I replaced after buying used?
Hi all,
I purchased a FEH2006 two months ago and it has 159k miles. I did oil change, air and hybrid air filter change, sparkplugs and fuel pump.
What else do you guys recommend I should replace first hand to keep it working fine? I need to replace the ac pump because of the noise, but after then idk.
Thank you in advance.
Old Sep 24, 2019 | 12:26 AM
Shane Carr's Avatar
Default Re: What parts should I replaced after buying used?
Remove main driveshaft have carrier bearing replaces, new u joits and get it ballanced. About $400. Replace 12v battery with glass matt. Yellow top optima. Replace blend door actuator for ev battery cooling system. Change cvt fluid. Transfer case also. Get fans checked in ev battery for proper operation. If fans acting up have tech CHECK ELECTRICAL CONNECTORS TO FANS. they were weak and not conducting fully on two of my ev batteries. 06 esc hyb and 07 mariner hyb.. i will b adding additional cooling fans ( pushers) hayden 22 amp combined. Make sure you have proper charge ALWAYS in ac system
Shane Carr
Mercury Mariner Hybrid
17
Aug 30, 2021 12:25 PM
Shane Carr
Oct 8, 2019 10:53 PM
Organica1
Jul 6, 2015 12:36 PM
sweidans
Jun 25, 2010 11:08 PM
