Ford Motor Company Ford, Mazda and Mercury hybrids
2006 Ford is scape hybrid not going into EV mode, showing code for hybrid battery fan
Old Jul 24, 2016 | 07:56 PM
Hybrid2006's Avatar
2006 4WD ESCAPE FEH 140k
Default 2006 Ford is scape hybrid not going into EV mode, showing code for hybrid battery fan
Hello everyone… I am desperate for some advice.
I have a 2006 Ford escape hybrid with 180,000 miles on it. My air-conditioning was recently getting warm in a recharge just didn't do the trick. I had the compressor replaced and now the air-conditioning is ice cold . Unfortunately as soon as I did that repair the truck does not go into EV mode anymore and I am constantly hearing the air-conditioning clicking and cycling even if the compress. Unfortunately as soon as I did that repair the truck does not go into EV mode anymore and I am constantly hearing the air-conditioning clicking and cycling even if the cabin air conditioning is off. I immediately started getting the stop safely now and red triangle and it was throwing codes that the two hybrid battery fans are not working. I am able to drive the truck in regular gas mode and not stall if I keep the air conditioning on Max AC.
Could this be a complete coincidence that this started right after the air conditioning compressor job was done? My mechanic is not convinced that doing the fans will solve the problem because he doesn't feel that the batteries are getting all that hot. Does anyone feel that the constant cycling of the new compressor will stop once the fans are replaced? Could the fans be triggering the compressor to continuously cycle? I am at the point that I'm not sure if I should put any more money into this truck. Can anyone help?
Old Sep 29, 2016 | 10:21 PM
Bizarro's Avatar
Default Re: 2006 Ford is scape hybrid not going into EV mode, showing code for hybrid battery
I'm not sure if I have any advice to help you, but I've had a similar problem and some things to look out for...
Last year my Escape would not go into EV mode after 30 minutes or so of driving in the morning, I changed the hybrid battery fans (myself, $200 and 1 hour of my time- and I'm not mechanically inclined, it's not a very complicated fix). It fixed the problem... for about a year. I encountered the same problem recently, changed the fans again AND the blend door actuator ($20 and half hour of time, again, easy fix), and my Escape still won't go into EV mode after 30 minutes of driving.
I was told from Ford today that my AC Compressor is leaking (even though my cabin AC is ice cold like yours), it's causing all of the pressures to be off, and if the pressures are off the valve won't direct the AC to the rear.
So even though I haven't fixed my problem yet, my questions for you would be:
-Is the AC line to your battery in the back cold? There are two thin metal tubes that run to the rear battery, they're on the drivers side and you can see them behind the rear tire through the wheel well. If one of them is cold (when the can is on and has been running for a while), then the AC is running to the rear. If neither are cold, then the high and/or low refrigerant pressure might be off keeping it from being directed to the rear when needed.
-When the car is not going into EV mode, can you hear the fans working in the back at all? Go in the back trunk area and feel the metal area where the battery is, is it hot? If so your hybrid batteries are overheating. The smaller rear rectangular(ish) portion of the battery panel is where the fans are, can you hear or feel movement underneath when you put your hand on it? If not, you may have to replace your hybrid battery fans.
So depending on what you find, either your mechanic should check your AC refrigerant pressures to proper levels (it may be out of range), or it could actually be your hybrid battery fans (if it's getting hot back there and you can not hear the fans).
Hope that helps a bit, good luck! And please post updates when you figure it out- it might help someone with a similar problem in the future (...or me!).
car2slo
Jan 12, 2016 06:16 PM
Hybrid2006
Jul 3, 2014 08:21 AM
skippy45
Jul 28, 2012 02:42 PM
08hybridok
Jun 30, 2008 10:08 PM
