Your FE Killer?
Old Jan 20, 2009 | 03:04 PM
GaryG's Avatar
Default Re: Your FE Killer?
Originally Posted by Bill Winney
In my Escape I see little difference in mileage except 1. High altitude such as in Wyoming, where mileage goes up as expected & 2. Cold weather (no surprise).
Hi Bill
Is your Escape a hybrid? The reason I ask is the Atkinson 2.3L has very little low RPM torque compared to the standard 2.3L or V6 engine in the Escape. This causes the FEH to reach 100% max engine load and electrical motor assist at a very low RPM. With straight gas, that little more power makes a big difference in keeping under 100% engine load during acceleration. If you can keep engine load down and avoid draining the battery state of charge with assist, you can get over 70mpg on straight gas in the FEH. Using the best hypermiling skills I know, I could not hit 50mpg on the same flat roads on E10. Rolling hills at the '07 MPG Challenge I managed 61.8mpg on E10 with perfect condition in a FWD FEH.
I've compared straight gas and E10 since '05 many times till E10 was mandated ~ May '08 in my '05 FEH. The results were constantly the same with mileage drops with E10. My oldest Son (MIT Grad) comes down from the cold weather and drives my '05 FEH to Miami and all over Florida for vacation every few months and this last time he reported lack of power above 70mph. I checked the SGII and found 6,000 rpm max and 80mph max and thought the E10 was giving him problems at those speeds. Sure enough when I took it out on I-95 at 70mph and over, I was having a hard time keeping the engine load under 100% and electrical assist on E10 at those speeds. Never had that problem on straight gas.
GaryG
Old Jan 20, 2009 | 04:16 PM
GaryG's Avatar
With regard to headwind you are captive to the electric machinery inherent in a hybrid. In a conventional car when you face a headwind you push on the gas pedal & the engine stays at the same rpm with more fuel going to the cylinders.
Notice that when you want to go up power in the hybrid the engine rpm goes up. This happens because to make the electric machines go up power you have to either increase the fields inside the machine (this has a limit with ferromagnetic saturation of the filed poles) or increase the rpm of the machines.
Premium versus regular makes no difference in engine power, the only difference is the additive package the gas company puts in.
I've found by mistakenly putting premium 93 octane in my tank, it was almost as bad a E10 for a MPG drop. Ford recommends 87 octane in all FEH/MMH and I find I get the best mileage with it. Ford also recommends using no additives and can void your warranty if you do in the '09 FEH/MMH according to the owners manual.
GaryG
Old Jan 20, 2009 | 05:07 PM
MyPart's Avatar
I had the same experience.
Through a local grocery chain discount deal I was able to get 45 cents off per gallon up to 20 gallons. I took my Mustang (which requires premium) and the FEH to the same pump. I filled the Mustang and FEH for really cheap but paid for it later that same day when I went out on the Interstate for a 250 mile round trip. This trip is usually good for about 31-32MPG (at PSL). The best we could do was 27-28MPG (at PSL). That's the last time I'll put premium in the FEH. Even if I'm getting a great deal on the it.
The old MG uses standard gas so it will be the fill-up buddy next time we cash in the gas perks.
On a side note, the Mustang seems to get a little better mileage when I use premium over the middle grade. Granted, I have to pull back the timing a bit with middle grade to keep detonation at bay. It's just not worth the hastle when I factor in all the variables in my head so I just use premium and drive it less these days. Besides I love driving the FEH and playing the FE game.
Old Jan 20, 2009 | 06:57 PM
Yes, my Escape is a hybrid & AWD.
The octane rating should make no difference in engine performance. In Wyoming they sell 85 octane. Since the altitude is above 5,000 feet the physics of the engine pressures means that an engine that must have 87 at sea level will run fine above about 5,000' with 85.
Octane rating only tells you its resistance to detonation but nothing else. Energy wise it is as good as 87 or 85. Any ethanol in your gas means you have less energy available so the engine should not run as well.
I understand the difference between the Atkinson & Otto cycles. My point about the electric machines, since they have to supplement the ICE, is that the way they increase power is to raise rpm (watch the engine on speed control). And so the engine ups its rpm to provide that with the associated loss of energy to higher internal friction at higher rpms.
Over the years I have put the least expensive gas I can find in my cars and tracked the fuel mileage: 71 Plymouth Duster (225 slant 6) - 164,000; 92 GMC Suburban (350 V8) - 366,000 & going strong; 01 Mustang Cobra (4.6L DOHC)- 257,000 & going strong.
I run the Mustang (4.6L DOHC & will it pull!!) on a 50-50 mixture of 93 & 85 octane up here in Wyoming (equivalent octane is 88). I run 85 in the Suburban. Using an octane above that which is needed by the engine design is unnecessary.
I track both tank to tank and long term mileage. My Escape Hybrid has 41,000 on it. I find that when I have a really good tank mileage that it gets taken back within a tank or two, so if I can't show about the same mileage over 1-2,000 miles I don't count it.
Curated Content Editor
Sep 11, 2012 02:29 PM
tigerhonaker
Jan 21, 2006 08:50 PM
tonto
Nov 4, 2005 02:40 AM
StaggerLee
Honda Insight
Oct 6, 2005 07:47 PM
Delta Flyer
Jul 22, 2005 08:56 AM
