Stop Safely randomly in cold weather - C1862,P0A27 ,P0562
Old Dec 13, 2020 | 10:05 AM
FEH_FEH's Avatar
Default Stop Safely randomly in cold weather - C1862,P0A27 ,P0562
Hello,
We have a 2005 Ford Escape Hybrid that runs fine in the warmer months. However, when it gets cold the car will give the orange triangle and pull over safely message. Sometimes this happens instantly. Other time it will be after an hour of driving. Here is the android forscan lite results. I'm having issues finding what this code really means: Code: C1862 - Contactor Circuit Failure
===TCM DTC P0562-FF===
Code: P0562 - System Voltage Low
Module: Transmission Control Module
===END TCM===
===PCM DTC P1A10-FF===
Code: P1A10 - Hybrid Powertrain Control Module - Battery Disabled
Module: Powertrain Control Module
===END PCM===
===OBDII DTC ===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII===
===4X4M DTC ===
Module: 4X4 Control Module
===END 4X4M===
===ABS DTC ===
Module: Antilock braking system
===END ABS===
===BCM DTC P0A27-20===
Code: P0A27 - Battery Power Off Circuit
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Battery Control Module
===END BCM===
===BCM DTC C1862-20===
Status:
===END BCM===
===EPS DTC ===
Module: Electronic-Controlled Power Steering
===END EPS===
===IC DTC ===
Module: Instrument Cluster
===END IC===
===RCM DTC ===
Module: Restraint Control Module
===END RCM===
===GEM DTC ===
Module: Generic Electronic Module
===END GEM===
Appreciate any help!
Old Dec 13, 2020 | 11:25 AM
Default Re: Stop Safely randomly in cold weather - C1862,P0A27 ,P0562
I've never shot this problem but it could potentially be as simple as a bad/open service disconnect plug on the High Voltage Traction Battery.
http://www.nicksmustangranch.com/Ser...3003.htm#PS2-G
G1 INSPECT THE SERVICE DISCONNECT PLUG FOR AN OPEN
  • Ignition OFF.
  • Remove the service disconnect plug and inspect for an open. Make sure that the high-voltage fuse resistance is less than one ohm. If the high-voltage fuse is open, refer to DTC P0A95 for instructions. Refer to High-Voltage Traction Battery Systems Depowering in this section.
  • Is the service disconnect plug open?
Old Dec 14, 2020 | 08:22 AM
FEH_FEH's Avatar
Thanks Alex! I'm going to replace it and see if that helps.
Old Dec 14, 2020 | 09:05 AM
Hope it helps. Otherwise you're going to be shooting that Pin-40 test and I have no idea what the P0562-FF System Voltage Low might indicate, other than the obvious. You should try to get a reading on the voltage level of the HVTB with Forscan.
Mikee
May 28, 2014 04:32 AM
mullenba
Dec 27, 2012 08:28 AM
Pravus Prime
Nov 27, 2009 10:46 PM
