Part number help needed, please.
Old Dec 23, 2020 | 09:19 AM
GatorJ's Avatar
Default Part number help needed, please.
I have a 2009 Ford Escape Limited Hybrid, manufactured in 10/2008. I need the part number for either the connector or the entire wiring harness that runs from the front of the HVTB on the DRIVER'S side. This is the large square connector that bolts in, not the orange, high voltage connector on the passenger side. I would consider this to be more the data/communications harness.
My FEH's previous owner broke mine trying to remove it without realizing it bolted in.
Thank you in advance.
Old Dec 23, 2020 | 12:35 PM
Default Re: Part number help needed, please.
I believe you're referring to the 40-pin connector C4227A on the HVTB. This connector is referenced in a lot of the HVTB pinpoint tests for various DTCs. This is all I've been able to find. It's part of Harness #14405 and the Base Part Number of the *connector* is 10B759. I don't have anything on the "other side" of the connector, i.e, with the bolt holes showing. But maybe this will get you started if you can contact a Ford dealer who has the full parts manual. Sorry if this is the wrong connector or a dead end.
FEH C4227A Connector - HVTB
Old Dec 23, 2020 | 03:32 PM
GatorJ's Avatar
@AlexK. That was very helpful, thank you. The partial harness number you listed confirmed some information a good friend with a repair shop found....
9M6Z14405AA
GatorJ
Ford Motor Company
Dec 22, 2020 01:22 PM
Miles
Sep 2, 2019 06:39 AM
WRXSTi
Jul 9, 2007 03:40 PM
rdinatal
May 8, 2007 12:09 AM
HoslerD
Oct 14, 2006 04:37 AM
