Part number help needed, please.
I have a 2009 Ford Escape Limited Hybrid, manufactured in 10/2008. I need the part number for either the connector or the entire wiring harness that runs from the front of the HVTB on the DRIVER'S side. This is the large square connector that bolts in, not the orange, high voltage connector on the passenger side. I would consider this to be more the data/communications harness.
My FEH's previous owner broke mine trying to remove it without realizing it bolted in. Thank you in advance. |
Re: Part number help needed, please.
I believe you're referring to the 40-pin connector C4227A on the HVTB. This connector is referenced in a lot of the HVTB pinpoint tests for various DTCs. This is all I've been able to find. It's part of Harness #14405 and the Base Part Number of the *connector* is 10B759. I don't have anything on the "other side" of the connector, i.e, with the bolt holes showing. But maybe this will get you started if you can contact a Ford dealer who has the full parts manual. Sorry if this is the wrong connector or a dead end.
https://cimg3.ibsrv.net/gimg/www.gre...77212f9c36.png FEH C4227A Connector - HVTB |
@AlexK. That was very helpful, thank you. The partial harness number you listed confirmed some information a good friend with a repair shop found....
9M6Z14405AA |
