Stock Hybrid + engine block heater = poor mans PHEV?
Old Oct 12, 2007 | 11:57 AM
  #71
TeeSter's Avatar
Default Re: Stock Hybrid + engine block heater = poor mans PHEV?
Originally Posted by Mark E Smith
I dont know about the FEH specifically but all block heaters I have seen go into the coolant on the block usually where a freeze plug would be. Yes you will loose coolant. Pick up some G-05 or Motorcraft Gold coolant and when you replace it be SURE to use distilled or de-mineraled water.
Okay.... good to know. I've been thinking about getting one installed myself in case I end up in Houghton in the U.P. of MI or something at my old alma matter someday.
Old Oct 12, 2007 | 12:48 PM
  #72
Mark E Smith's Avatar
Omnia Gloria Fugit
One of the prius owners in Houston uses one so he can go into ev ALLOT quicker on cold start. I have been thinking about one also for that reason, but my Ford dealer says they are back ordered. ( Texas rarely needs block heaters)
Old Oct 12, 2007 | 02:44 PM
  #73
tya2agt's Avatar
If someone could post a picture of where the block heater plug goes that would be helpful. Just came back from the local dealer that actually sells Hybrids sort of! Mine was the first semi-recall campaign done by them on the resistor replacement. It took them 5 hours! From 9 AM until 2:30 PM. They figure the block heater installation will take 4 hours!!! Has anyone got instructions??? I have seen a couple of pictures on this list, but not all of the ones I would need for the block heater installation if done by myself...
Rocky
Old Oct 12, 2007 | 03:42 PM
  #74
DavidH's Avatar
2008 Escape Hybrid Owner
If you warm up the engine with a block heater, I expect you would see better MPG on the display becuase you are not burning fuel to warm the engine. But, it may be a false savings if warming the engine while driving uses less fuel energy than plug electric energy.
Old Oct 12, 2007 | 04:05 PM
  #75
Ah... but it will ALWAYS cost YOU less if you get to plug it in at work.
-John
Old Oct 12, 2007 | 04:07 PM
  #76
FWIW Norway has plug-in cars now that go 66 miles on a charge.
No big deal you say? Think Again.
They recharge in under 10 minutes!
Old Oct 12, 2007 | 06:25 PM
  #77
Omnia Gloria Fugit
IIRC someone did an analysis and 2 or 3 hrs a day was something like $4 in electrical energy cost. Savings would depend on your trip distance, shorter trip would have MORE savings
Old Oct 12, 2007 | 07:02 PM
  #78
Rocky
I had my engine block heater installed at the Ford Dealership and an oil change (I provided the Mobil 1 oil) performed and I was only charged 1 hour labor. My total cost for this was something like $97.00.
Old Oct 13, 2007 | 02:55 AM
  #79
EOppie's Avatar
HEV's are your friend
Thats for labor only correct? otherwise you got a heck of a deal
Old Oct 16, 2007 | 06:35 PM
  #80
Rechecking my bill from the Ford Dealership, I was charged $80 for labor to install the engine block heater.
