Scanguage Codes
Old Jan 11, 2008 | 12:42 AM
08hybridok's Avatar
Default Scanguage Codes
I thought we might have a sticky for all the SG Codes that have been found so far. I printed a small list a few months ago, but I know it grows, almost daily it seems
Just curious why there's not a sticky yet.
Old Jan 11, 2008 | 06:37 AM
Default Re: Scanguage Codes
Good point. And Carl, may we have the "long list" please?
We of course, accept them "as is" and without gurantee!
( and promise not to complain if some don't work as expected )
Thanks!
-John
Old Apr 6, 2008 | 10:57 PM
GeekGal's Avatar
bump. Looking for the same thing.
Old Apr 6, 2008 | 11:35 PM
08hybridok's Avatar
The best I found so far is (Carl's?) Pic in the share section (I keep forgetting about that area. That has a bunch. but I know there's more just floating around in the forums.
https://www.greenhybrid.com/share/fi...EH_xgauges.JPG
Old Apr 7, 2008 | 07:22 AM
GeekGal's Avatar
Perfect, thank you! I knew I'd seen something that presented it in a quick and tidy way, but I was having no luck locating it via the advanced search in the forums. No wonder...I probably originally saw it in the photo area. I forget about that being there, too (haven't added to it in over a year!)
Thanks again!
Old Apr 7, 2008 | 07:59 AM
Yeah... that's a cool list to get started with.... that's still the short list.
There is a much longer list with more details than you'd ever want to know, and ones the car rarely uses that you'd only need to trouble shoot rare problems. That is a very good list... of the "favorites" so to speak!
Now, anyone know were to get such a list for Honda!?
-John
Old Apr 7, 2008 | 08:17 AM
Exclamation Re: Scanguage Codes
TIP:
Long Term Fuel Trim is a good one to watch if you are concerened about ethanol.... if it is in your gas or not, and by how much.
LFT will go up by +3 to +4 for each 10% ethanol. It bounces around based on engine load, so you need to take a running average, not just one reading.
Under light engine load, and at near sea-level, this LFT number should hover around ( average out to ) zero.
The number goes negative ( less fuel used ) at high elevations.
If you change blends of gas, give the car at least 30 miles to re-adjust.
I was mixing my own E20, E30, E40, and like clockwork, the LFT went up in descrete moves of about +3.5 each time. About +14 to +16 for E40, and you don't get an error or check engine lamp unless the car exceeds +/- 25% in a 2005, 28% in an '06 or '07, and 29% in a '08.
For some reason, the newer cars are "allowed" slightly richer amounts before tripping a MIL.
Though you may like to know!
-John
Old Apr 7, 2008 | 02:49 PM
Johndixs's Avatar
Anyone know if engine oil pressure is available?
Thanks,
john Dixson
Old Apr 8, 2008 | 09:51 AM
Should be available, but I don't know off the top of my head.
I'll dig a little.
I know I can get a value of 170 for oil pressure with engine warm, but I don't know what units that is.
-John
mikemc
56
Aug 12, 2009 10:50 AM
Dennis
Jul 26, 2007 07:57 AM
everythingsgonegreen
Sep 18, 2006 08:10 PM
Tim K
Aug 17, 2006 06:07 AM
