rescuing a clean 05, is there a thread to help me?
Old Nov 14, 2017 | 02:55 PM
  #31
newbie1kenobie's Avatar
Default Re: rescuing a clean 05, is there a thread to help me?
i removed my top o2 sensor after reading a thread on the p0562 code that was caused by clogged exhaust, idled for a while, no ssn!
put the sensor back in and ssn, guess i will remove the exhaust and clean it
also must have jump charged my bank enough last night that today i was codeless for the first time, except the p1000, before the sensorless idle, then got a code for exhaust leak and the p0562, so i will continue the jump charging
also the bank vent door can be heard as it actuates
Old Nov 14, 2017 | 08:40 PM
  #32
Plugged cat?
Old Nov 17, 2017 | 03:03 AM
  #33
got the exhaust manifold/cat off after a fight and it looks clean, have read that a small amount of restriction can be a problem for the computer, soaking it in dawn
anyone know where to get the round headed splined studs (pipe flange) that look like mini wheel studs? avoiding the dealer? bolts may have to do
the rear cat will soak tonight
is there a simple test to be sure the honeycomb is clean before i put it back on?
Old Nov 17, 2017 | 07:31 AM
  #34
D-mac's Avatar
Do you know if your ICE is running the correct air/fuel mixture at idle and wide open throttle (and the range between)? A clogged exhaust might indicate there's some other issues with the engine.
Old Nov 17, 2017 | 10:20 PM
  #35
would there be a trouble code for that or ?
Old Nov 18, 2017 | 04:34 PM
  #36
D-mac's Avatar
An OBD-II scanner should be able to read in real time. Might be a good idea in your case to check fuel trim and get an idea how healthy your engine is.
Old Nov 21, 2017 | 04:58 PM
  #37
its running great now, didn't do anything to the rear cat yet, noticed water dripping from holes in it, gotta check if they are drilled or rotted
showing 25mpg at the end of a 25 minute drive at 30-60mph
interstate test tomorrow
Old Nov 21, 2017 | 05:59 PM
  #38
So, plugged cat?
Old Nov 21, 2017 | 11:10 PM
  #39
yep, after using a lot of hot water to rinse the 3 ounces of dawn out of the cat it still put out a big stinky vapor cloud, ran it a few short times to clear it then bolted on the rest of the exhaust
Old Nov 23, 2017 | 07:10 AM
  #40
ssn at 65mph then got it to 70 when accelerating more gradually, will check the dtc's tomorrow, plan to pull off the rear cat and check it
