rescuing a clean 05, is there a thread to help me?
Old Nov 8, 2017 | 10:58 AM
newbie1kenobie's Avatar
Smile Re: rescuing a clean 05, is there a thread to help me?
Amazon Amazon
i see now t need to use the mini disc that was included
hope to have a charger today, going out of town tomorrow
Old Nov 8, 2017 | 11:25 AM
econoline's Avatar
Default Re: rescuing a clean 05, is there a thread to help me?
Thanks, hope you get it working. I'm about to order this one: https://smile.amazon.com/gp/product/...P6N0Z6QL&psc=1
Old Nov 8, 2017 | 05:05 PM
I have one of those. It seems to be a little better than most of the $10-12 ones when working with Torque Pro.
Old Nov 8, 2017 | 05:57 PM
econoline's Avatar
Thanks. I'm hoping it will also work with Forscan too. I need to start troubleshooting a problem with loss of regen braking, but no codes on SG or dashboard indicators. I thought Forscan might be more comprehensive than SG.
Old Nov 8, 2017 | 06:19 PM
one of these threads mentioned grounding problems on the brakes, maybe it was a regen thread, did you check them?
got half way through the jump starts, had to run into work, starting over, should be done in an hour
Old Nov 8, 2017 | 06:32 PM
econoline's Avatar
Good tip, thanks, I'll search for that.
I'll start a new thread on my problem, don't want to hijack yours.
Old Nov 8, 2017 | 07:27 PM
  #27
no changes after jump charging, will try again tomorrrow
Old Nov 12, 2017 | 04:37 PM
  #28
still no change other than the recharge button lights up but there is no draw on the 12v battery, guessing this means the bank is full
still getting the code for tcm low voltage
when i start the engine it idles fine for a few seconds, then starts to hunt for a few then the ssn, makes me wonder about the throttle body
Old Nov 12, 2017 | 07:26 PM
  #29
Are you doing the jump start with the key off?
Old Nov 13, 2017 | 03:42 AM
  #30
would not charge either way, but this morning, after sitting with 12v disconnected overnight, it has just responded normally
will continue after work this afternoon
