rescuing a clean 05, is there a thread to help me?
Old Mar 1, 2018 | 02:57 PM
  #51
newbie1kenobie's Avatar
Default Re: rescuing a clean 05, is there a thread to help me?
After a good warm-up trip the btm reached 90's and the performance was suffering, rear ac was on, engine was 180's, battery 120.5v, 52%, a.c. low was 60psi, high was 190, ambient 80, I think true ambient must have been higher in the grill/radiator area that is blocked in front with sign plastic
so the chart says maybe a bad compressor, I will find a shop that does free a.c. checks to maybe get more info
should have my old Nissan sold soon for tech money, though I think I will tackle the thermostat myself, maybe it will help the a.c. somehow
Old Mar 1, 2018 | 03:07 PM
  #52
Rex B's Avatar
If it were mine, I would change that thermostat immediately, and then have that compressor valve changed out, which also requires refrigerant recharge. Then see what happens. Alternately, a compressor is $200 and will have a new valve in it.
Old Mar 2, 2018 | 03:57 PM
  #53
New thermostat helped but still only 120v, got a good look at the compressor and it looks like original, serpentine belt was easy, have been fearing the things for decades
Old Mar 2, 2018 | 05:14 PM
  #54
120V? What's measuring 120V?
Old Mar 2, 2018 | 05:18 PM
  #55
traction battery, hoping I programmed the s/g wrong, checking it tomorrow
Old Mar 2, 2018 | 05:22 PM
  #56
Yes, you programmed the s/g wrong. Traction battery will not operate at 120V.
I don't know what the actual threshold is, but a mariner hybrid at resting 248V wouldn't start. Had to be manually charged.
Operating voltages are way up there - probably around 325-350V with swings well above and below that during regen and assist, respectively.
Old Mar 3, 2018 | 05:28 AM
  #57
320 btv, then noticed-9312, -9809, -A306.......
After 8minutes -B274
A803, 9299, 9809? Cell #, time?
btm 62.6
soc 45.6
these came up with key on, engine off, no warm up
Old Mar 3, 2018 | 09:20 PM
  #58
Emailed Brian at BSG, he says it's the scroll valve in the back of the compressor that's failed. Will get a shop to recover the Freon, hope Napa has the part, great if I can swap it with the compressor in place. Read that the valves are sold with a filter to protect it, also can put the old valve in reverse but efficiency suffers.
Got on the highway for a few miles, cool weather, temps on sg2 were good, ran great, dash showing 24mpg, time to setup the sg2 for mpg.
Old Mar 6, 2018 | 10:37 AM
  #59
Napa's scroll valve didn't come with the filter so I gave it back, amazoned it for $10, $40 savings.
Working out of town for a week or 2, will have money for a tech if the mpg still sucks, hoping it's an update or?
Old Mar 17, 2018 | 04:42 PM
  #60
Dratts! Week 2 out of town, making money but can't work on the a.c. Will get to see how the bank holds up.
