Rear Shocks
Old Nov 13, 2006 | 05:38 PM
TeeSter's Avatar
Default Re: Rear Shocks
Originally Posted by Tim K
It wasn't much better at 35psi either. The vehicle just seems too bouncey for me and potholes really seem to hit hard. I don't want to feel like I'm driving in a big ole Cadillac and feel nothing though either. I actually enjoyed the ride of my '01 Grand Cherokee even though it had solid front and rear suspensions. I really felt the road and at the same time felt the suspension handled everything the road threw at it. I realize they are very different vehicles but I'd like to get closer to that.
I'd love a shock suggestion.
Just don't fall into the old mistake that was done with the Explorers. My father and brother both work for Ford. Part of the inside story on the Bridgestone issue was that in order to soften the ride and get rid of the jarring of potholes and such, people were mistakenly told by various sources that they could let air out of their tires and run them at 26PSI or less. This causes extra heat in the tire and premature failure. In some cases people weren't observant and their pressures got even lower.
From the standpoint of most people in the know... the whole Bridgestone issue was a combination of things. One was that the tires did seem to fail at a higher rate than Goodyear tires on the same vehicle and the second was that people were either setting their tire pressures too low or not keeping track of them well enough accelerating the failures as well. As for the vehicle having a tendency to roll after a tire failure... I remember reading somewhere that once the tire failed, Chevy Yukon's actually had a slightly higher chance of rolling.... they just weren't having the same number of tire failures.
Anyway.... that was longer than necessary.... all I wanted to say is don't let anyone tell you its safe to let more air out of your tires than the recommended pressure 35PSI.
Old Nov 13, 2006 | 05:41 PM
TeeSter's Avatar
I have the 4WD and haven't felt any of the issues you two are discribing. I don't know if its because of the 4WD or just that I'm not sensitive to it.
v90hamm77
Oct 7, 2015 07:16 PM
us035976
Feb 15, 2015 07:30 AM
Ontario07Civic
Oct 7, 2008 11:46 PM
FairfaxTCHer
May 2, 2007 06:10 AM
Tim K
Oct 16, 2006 10:34 AM
