PSA: Easy repair for ignition/key problems.
Old Jan 13, 2021 | 11:58 AM
GatorJ's Avatar
Default PSA: Easy repair for ignition/key problems.
If you are experiencing the all too common ignition key not starting your FEH until you push it in harder issue, try this before you before you start tearing your column apart and replacing parts: A minor modification to the housing for the lock cylinder, no parts needed.
Old Jan 14, 2021 | 07:48 AM
Rex B's Avatar
Default Re: PSA: Easy repair for ignition/key problems.
Great tip, thanks for posting this.
Old Jan 31, 2021 | 05:41 PM
Not having it yet but very duly noted. Thank you!
Old Mar 2, 2021 | 03:34 PM
teperilloux's Avatar
I did this repair and while not QUITE as easy and the video shows, it solved my no start problem easily!
Sfork
Oct 21, 2014 02:29 AM
84GT Ragtop
Aug 11, 2012 04:24 PM
sobayimage
Nov 5, 2009 04:08 AM
IMAhybrid
Off Topic
Apr 13, 2006 10:11 AM
nitramjr
Dec 22, 2005 09:50 AM
