P1A10, Another "Stop Safely Now" Thread
Old Oct 6, 2020 | 11:32 AM
wing43215's Avatar
Default Re: P1A10, Another "Stop Safely Now" Thread
Took me forever to get forscan. Here is the log:
===PCM DTC P1000:00-2B===
Code: P1000 - OBD Systems Readiness Test Not Complete
Status:
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM DTC P1000:00-2B===
===PCM DTC U0111:00-2B===
Code: U0111 - Lost Communication With Battery Energy Control Module A
Status:
===END PCM DTC U0111:00-2B===
===OBDII DTC None===
Successful DTC reading, no error codes found
Module: On Board Diagnostic II
===END OBDII DTC None===
===ABS DTC U3003:16-68===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
- Previously Set DTC - Not Present at Time of Request
- Test not complete
Module: Antilock braking system
Freeze Frame :
-OUTTMP: -14 °C - External Temperature From Sensor
-ABS: Inactive - ABS
-AYC: Inactive - AYC
-BTCS: Inactive - BTCS -201D
-HDC: Inactive - HDC
-RSC: Inactive - RSC
-BTC: Inactive - BTC
-VAC_BST_ST: Inactive - Active Vacuum Booster State
-BST_REL_SW: Inactive - Booster Release Switch State
-HYD_PMP_ST: Active - Hydraulic Pump State
-VPWR_ABS: 10.00 Volt - Module supply voltage
-VSS: 0.0 km/h - Vehicle Speed
===END ABS DTC U3003:16-68===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===TCM DTC P0562-FF===
Code: P0562 - System Voltage Low
Module: Transmission Control Module
===END TCM DTC P0562-FF===
===TCM DTC P0A0A-FF===
Code: P0A0A - High Voltage System Inter-lock Circuit
===END TCM DTC P0A0A-FF===
===APIM DTC B1136-60===
Code: B1136 - Audio Steering Wheel Switch 2 Circuit Failure
Status:
Module: Accessory Protocol Interface Module
===END APIM DTC B1136-60===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===4X4M DTC None===
Module: 4X4 Control Module
===END 4X4M DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===IC DTC B1318-20===
Code: B1318 - Battery voltage Low
Status:
Module: Instrument Cluster
Diagnostic Trouble Code details
Battery voltage Low
Possible causes are:
Battery voltage line - open or short
Blown EPS fuse
Poor battery condition
EPS CM malfunction
Poor connection of each connector
Control Module
===END IC DTC B1318-20===
===IC DTC U2472-20===
Code: U2472 - Unexpected Ignition State
Status:
===END IC DTC U2472-20===
===IC DTC U2023-20===
Code: U2023 - Fault Received from External Node
Status:
This DTC may be caused by :
Short circuit on the CAN line.
Open circuit on the CAN line.
There is a time out between two modules on the CAN bus
There is Interference on the CAN bus
There may be other modules on the CAN communication data line that are not communicating and are timing out.
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END IC DTC U2023-20===
===IC DTC B1600-20===
Code: B1600 - At some time since last clear the ignition was switched on without any key code being read.
Status:
--- Possible Causes --------
PATS ignition key transponder signal not received
NO transponder signal detected during start
-Suspect Ignition key PATS antenna or wiring Module
===END IC DTC B1600-20===
===IC DTC U2511-60===
Code: U2511 - CAN communication bus fault
Status:
===END IC DTC U2511-60===
===IC DTC U0111-60===
Status:
===END IC DTC U0111-60===
===FDIM DTC None===
Module: Front Display Interface Module
===END FDIM DTC None===
===SDARS DTC B1031-60===
Code: B1031 - SDARS Satellite Antenna Open
Status:
Module: Satellite Digital Audio Receiver System
===END SDARS DTC B1031-60===
===SDARS DTC U0184-20===
Code: U0184 - Lost Communication With Radio
Status:
===END SDARS DTC U0184-20===
===SDARS DTC U0255-60===
Code: U0255 - Lost Communication With Front Controls Interface Module
Status:
===END SDARS DTC U0255-60===
===HVAC DTC B12B8-60===
Code: B12B8 - Driver Blend Door Actuator, Slow or Door Obstructed
Status:
Module: Heating Ventilation Air Conditioning
===END HVAC DTC B12B8-60===
===HVAC DTC B12A5-60===
Code: B12A5 - Mode Door Actuator, Feedback Circuit Open or Shorted to Battery Voltage
Status:
===END HVAC DTC B12A5-60===
===HVAC DTC B12A6-20===
Code: B12A6 - Mode Door Actuator, Feedback Circuit Open or Shorted to Battery Voltage
Status:
===END HVAC DTC B12A6-20===
===HVAC DTC B298A-60===
Code: B298A - Mode Door Actuator Drive Circuit(s) Open
Status:
===END HVAC DTC B298A-60===
===GEM/SJB DTC None===
Module: Generic Electronic Module / Smart Junction Box
===END GEM/SJB DTC None===
File Type: txt
Old Oct 6, 2020 | 11:40 AM
What is the 12V battery voltage at the terminals?
Old Oct 6, 2020 | 04:41 PM
wing43215's Avatar
It's fully charged. I put a trickle charger on the 12V and it is less than 4 months old. Took it to autozone about two weeks ago and it came back good.
Old Oct 6, 2020 | 09:36 PM
You have multiple systems reporting low 12V.
Key on, engine off. Measure voltage across 12V battery terminals.
Old Oct 7, 2020 | 02:16 PM
wing43215's Avatar
See attached.
Old Oct 7, 2020 | 09:54 PM
Both terminals are disconnected. Need battery voltage with Key on, engine off where some load is being applied to the battery.
Old Oct 8, 2020 | 02:28 PM
wing43215's Avatar
Key on engine off.
Old Oct 8, 2020 | 02:42 PM
Okay, that confirms the battery can actually deliver a current and hold a voltage.
Now, disconnect the two terminals and short them together for 10 minutes. Ensure neither contact either battery terminal. This wipes every thing from every computer.
Once complete, reconnect 12V battery.
Key on- engine off.
Re-run DTC check.
Old Oct 9, 2020 | 03:51 PM
wing43215's Avatar
Key on- engine off.
Re-run DTC check.
Shorted the terminals for 10 mins. Key on, engine off. DTCS:
Status:
===PCM DTC P1A14:00-2B===
Code: P1A14 - Hybrid Powertrain Control Module - Transmission Disabled
Status:
===END PCM DTC P1A14:00-2B===
===PCM DTC P2450:00-E8===
Code: P2450 - EVAP System Switching Valve Performance/Stuck Open
Status:
- Malfunction Indicator Lamp is On for this DTC
- Test not complete
===END PCM DTC P2450:00-E8===
Status:
===OBDII DTC P2450-C===
Status:
- Confirmed - malfunction is confirmed
===END OBDII DTC P2450-C===
Status:
- Test not complete
Freeze Frame :
===RCM DTC None===
===APIM DTC B1318-20===
Status:
Battery Voltage Too Low
- Battery Voltage below 9.6volts
-Suspect Battery state of charge Charging system
===END APIM DTC B1318-20===
Status:
===OCS DTC None===
===4X4M DTC None===
===PSCM DTC None===
Status:
Battery voltage Low
Blown EPS fuse
EPS CM malfunction
Control Module
Status:
===IC DTC U2023-60===
Status:
Note:
===END IC DTC U2023-60===
Status:
Status:
Status:
===FDIM DTC B1318-20===
Status:
===END FDIM DTC B1318-20===
Status:
===SDARS DTC B1318-20===
Status:
===END SDARS DTC B1318-20===
Status:
Status:
Status:
Status:
Status:
Status:
===GEM/SJB DTC U0155-B0===
Code: U0155 - Lost Communication With The Instrument Panel Cluster Control Module
Status:
- Test not complete
===END GEM/SJB DTC U0155-B0===
===GEM/SJB DTC B1318-20===
Status:
===END GEM/SJB DTC B1318-20===
Old Oct 9, 2020 | 05:02 PM
I went completely cross-eyed halfway through that. It looks like it retained many prior codes as suggested by the numerous "not present at time of request".
Go into the DTC tab and clear the codes.
re-check codes.
