P1A10, Another "Stop Safely Now" Thread
Old Oct 26, 2020 | 11:09 AM
  #41
Default Re: P1A10, Another "Stop Safely Now" Thread
From the video, your HV battery is essentially disabled. Low SoC and charge/discharge powers of only 1500W.
I don't know the other codes.
Before proceeding, I would clear all codes, confirm they are all gone and then conduce another rmode balance to ensure your battery is at a high state of charge.
Once that is complete, sign up at https://www.motorcraftservice.com/ and get a 3 day subscription to the manuals for $22 or so. The single BCM code of P0A1F with no other BCM codes may indicate a fault with the battery computer, but that's said without knowing if any of the other codes might cause a battery fault.
Old Oct 26, 2020 | 01:54 PM
  #42
wing43215's Avatar
Cleared codes and re-balanced. It went.... very quick. Like, to quick.
Old Oct 26, 2020 | 03:03 PM
  #43
Yeah. Barely a minute.
What does the BCM table show (same screen you recorded video)?
Old Oct 28, 2020 | 04:45 PM
  #44
Hippo the Hybrid's Avatar
On our 2010 FEH the codes showing that related to a bad PCM showed up in FORSCAN as (WARN) [16:42:09.735] DTCs in PCM: P0562:00-2B, P1000:00-2B.
Old Oct 28, 2020 | 05:36 PM
  #45
wing43215's Avatar
Mine is showing p0a1f-60 - so dose this mean it is not the PCM? I haven't bought the repair books yet. I still need to run the BCM while it is running the rmode re balance. I wont get to it this weekend. Monday, hopefully.
Old Oct 28, 2020 | 10:01 PM
  #46
I don't know. Try searching under ford DTC p0a1f-60 and review the videos and posts. I would follow up on S. Keith's suggestion.
Old Nov 16, 2020 | 02:16 PM
  #47
wing43215's Avatar
Starting a new thread as this seems to be a new problem.
KermitDFrog
Nov 17, 2018 03:47 AM
Rupejeremy
Oct 29, 2013 04:23 AM
