new Scanguage software available
Old Nov 21, 2007 | 07:03 AM
  #131
glennb's Avatar
Red face Re: new Scanguage software available
Eric - do you have the NAV/Hybrid system "cartoon" display?
Old Nov 21, 2007 | 09:36 AM
  #132
econoline's Avatar
Default Re: new Scanguage software available
Originally Posted by EOppie
FYI I installed a SCII in my 06 4wd and my SOC appears to be working. Hovers around the mid 50's
Can you provide more details about your setup, like what "rate" and "mode" you are using on the SGII? Are the programmed values exactly the same as in post #7? Do you have the navigation system? Thanks.
Maybe there's still hope for getting SoC to work on an AWD '07.
Old Nov 21, 2007 | 12:46 PM
  #133
cmm's Avatar
cmm
I just had my SG2 upgraded and get a blank SOC reading. I have a 2005 Escape Hybrid FWD
Old Nov 21, 2007 | 03:04 PM
  #134
jmorton10's Avatar
I haven't read through all these posts, but all the X-gauges (including SOC) work perfectly in my 06 FEH 4WD.
I have two SGII's hooked together, one showing X-gauges & the other displaying trip functions.
~John
Old Nov 21, 2007 | 05:08 PM
  #135
econoline's Avatar
~John
Can you provide more details about your setup, like what "rate" and "mode" you are using on the SGII? Are the programmed values for SoC exactly the same as in post #7? Do you have the navigation system? Thanks.
Old Nov 21, 2007 | 06:33 PM
  #136
Originally Posted by Billyk
I will retry on Weds and post the results. Most likely I did something wrong.
Mine does work now. I inputted a wrong number and once corrected, my scangauge did display "off" for the 4WD value.
Old Nov 21, 2007 | 08:24 PM
  #137
jmorton10's Avatar
The values I used are the ones in the chart. My truck had factory NAV, but I removed it & replaced it with an Eclipse aftermarket NAV unit.
~John
Old Nov 22, 2007 | 01:32 AM
  #138
EOppie's Avatar
HEV's are your friend
I Do have the nav unit, with the "Cartoon" display.
I am set to HYBRID mode, and I used the code directly off of the LL website. I can check the car when I head home from work later today.
Old Nov 22, 2007 | 09:51 AM
  #139
I need your help please. ( from anyone with a ScanGauge and new v3.15 software )
I am curious if my Motor/Electronics Coolant pump has gone bad.
Would you please look at the following values and report what is
"normal" for your car after about 1 hour of highway driving?
MeC - Motor Electronics Coolant Temp
Mine is never more than 10 degrees above ambient.
45'F on a 35'F day, and 25'F on a 15'F day.
Gco - Generator Coil Temp
Mine slowly rises the longer I drive, mostly on the highway.
After 1 hour on a 30'F day, mine = 160'F
After 2 hours on a 30'F day, mine = 170'F
After 3 hours on a 30'F day, mine = 180'F
Mco - Motor Coil Temp
Mine slowly rises the longer I drive, but is about 10 degrees colder than the Generator Coil Temp, again, primarily at 60-70 miles per hour highway.
After 1 hour of highway on a 30'F day = 150'F and so on...
GiT - Generator Inverter Temp
Mine is about 90-100'F nominal, driving on the highway on a 30'F day
MiT - Motor Inverter Temp
Mine is about 85-95'F nominal, driving on the highway on a 30'F day.
Both inverters raise in temperature quickly when there is acceleration or regen braking, by 30 to 40 degrees in seconds, then quickly cool to the nominal above.
And just something interesting to look at:
My HPR - Horsepower produced:
At 58 MPH on cruise control on flat highway: 22 to 24 horsepower
At 68 MPH on cruise control on flat highway: 33 to 35 horsepower
Going up a slight ~3% grade at 68 MPH: about 50 horsepower
Going down a slight ~3% grade at 68 MPH: about 12 horsepower
Standing still at a light with ICE on: 4.4 horsepower.
TIA, -John
Originally Posted by DesertDog
Old Nov 23, 2007 | 07:54 AM
  #140
jmorton10's Avatar
~John
To add to this, today I tried the 4WD on/off X-Gauge & that works fine also. We had a little snow last night & my street was kinda slippery this morning. I stepped on it hard deliberately spinning the wheels & it immediately read "on" in the X-Gauge.
I absolutely love the SG with these new X-Gauge functions...........
~John
