new Scanguage software available
Old Nov 15, 2007 | 03:12 PM
  #111
Default Re: new Scanguage software available
Driving home after work- a short drive of just over 4 miles--my vehicle finally went into electric mode (about 2 miles into the drive) when the water temperature hit 155 degrees despite a 54.something SOC reading on the scangauge. It remained in electric mode until the water temperature dropped to 123 degrees despite a SOC reading of 42.2. The temperature has dropped today and was approximately 34-35 degrees with a brisk wind and frosty flakes.
Time to install the cardboard radiator wind block until someone can find something better.
Posting this information as a means of sharing data that our new Scangauge units can display. I wonder if this site should have a "place" where we could post photos and comments on the various Scangauge "readouts" we obtain from our day to day driving experiences.
Old Nov 16, 2007 | 08:57 AM
  #112
Sounds like a good idea to me.
What I'm positive of is:
In a 2005, a water temperature of 140'F is required to enter EV for the first time. Once in EV, you can drive EV down to a water temp of 125'F.
The SG monitors the temperature sensor about once per second.
However, the FEH itself, either monitors more slowly, or takes a 10 second average into account before deciding to turn the engine off or on.
Thus, you may see your SG at 140'F or higher a few moments before the ICE actually shuts down, and you may see your SG at 125'F or lower a few moments before the ICE kicks back on.
The true parameter specification is 125'F and 140'F, but the FEH does not "see" those temps at the exact same moment as the SG. They are pretty darn close in most cases though!
This A.M. I figured my Block Heater used 10 cents of electricity, but going EV right away on a 35 degree day saved me 35 cents of gas based on my last fill @ $3.16. That was 9.8 miles to work BTW.
So.... after 7000 miles ( 700 trips to work ) my block heater will have paid for itself!
Saving $0.25 a day on gas is not much, but it's still kind of fun to keep my MPG above 40 MPG in winter!
-John
Old Nov 16, 2007 | 11:17 AM
  #113
Carl, following your numbers exactly, MiT and GiT both display 0.0 with the engine running on a 50'F day.
Also, Motor Coil Temp, and Generator Coil temp are reading something, but not degrees F.
I get 25.5 to 28.5 for Coil temps with engine running on a 50'F day.
Mco
07E1224970
046285490670
3010
005A00050000*
*The MTH part looks unusual to me.
That's what you put on PID's for AMPs.
Originally Posted by DesertDog
The SoC offset is probably due to the fact that as a PID it is lagging the true SoC that the FEH is using. But, if you want to add 0.2% to it, just change the last digit of MTH to 2. Your MTH would then be 007D20000002.
If you suspect your motor electronics coolant pump is going south, I would monitor the Motor and Generator Inverter temps. They are:
TXD: 07E122496F
RXF: 04628549066F
RXD: 3008
MTH: 001200010000
NAM: MiT
TXD: 07E1224971
RXF: 046285490671
RXD: 3008
MTH: 001200010000
NAM: GiT
If these go above 150F, I would get the pump fixed ASAP. If they stay relatively cool, then probably your MeCT sensor is going bad.
Old Nov 16, 2007 | 12:13 PM
  #114
DesertDog's Avatar
Mco
07E1224970
046285490670
3010
005A00050000*
Just testing you.....For the Temps, the MTH should be 001200010140
The explanation: temps are in C multiply by 18 (0012), divide by 1 (0001), and add 320 (0140), then divide result by 10 (8 in RXF) to get a tenths reading in F.
Also, for the inverter temps, they are 2-bytes long so RXD should be 3010, not 3008.
Gotta stop posting without double checking....
Old Nov 16, 2007 | 01:02 PM
  #115
Hey Carl, you watch my back, I'll watch yours....
I want to plug my SGI into my SGIIxG.
I know how to physically do this.
Both versions use 8 wires, but the wire colors have changed over the years. The OBDII connector on the SGI simply unscrews. I was going to solder or crimp on an RJ45 connector.
Old SGI wires are Green, Purple, Yellow, Red, Blue, Black, Orange, Gray.
The black is ground, but that's all I know.
My SGIIxG has Brown, Brown Stripe, Green, Green Stripe, Blue, Blue Stripe, Orange, Orange Stripe ( not in that order ).
Any idea what each wire does so I can connect Tx to Tx?
I'm pretty good with trial and error, but would like to avoid the error part.
I called Joey at LL and he didn't know off hand and was going to ask Ron.
I'm going to have to sit at work and do nothing but wait and receive a big shipment tomorrow, so this is something I could really work on and get done tomorrow. TIA. I'll try the "revised" motor codes on the drive home.
-John
Old Nov 16, 2007 | 01:16 PM
  #116
Since there are ( at least ) 3 versions of ScanGauge out there, may I suggest for future reference:
SGI = Original, big box with amber screen
SGII = ScanGaugeII, compact, color screen, removable cable
SGIIxG = ScanGaugeII with xGauge
( and for GaryG that is capital "eye eye" not one-one! )
Old Nov 16, 2007 | 02:12 PM
  #117
Brady's Avatar
I would propose the scangauge equipped with xgauge would be just called SGII+
Or in my case SGII+-SoC
Old Nov 17, 2007 | 08:05 PM
  #118
I would rather go Scangauge I, Scangauge II, Scangauge III.
Old Nov 18, 2007 | 07:54 AM
  #119
DesertDog's Avatar
Billy, did you try the 4WD indicator xgauge? I have no way of testing it and was wondering if it worked.
Old Nov 18, 2007 | 11:52 AM
  #120
It works perfectly. Look in the recent thread of 29.5 SOC.
