new Scanguage software available
Old Nov 18, 2007 | 05:02 PM
  #121
DesertDog's Avatar
Default Re: new Scanguage software available
Originally Posted by Billyk
It works perfectly. Look in the recent thread of 29.5 SOC.
I don't see anything about the 4WD engaged xgauge in that thread. Did I somehow miss it??
Old Nov 19, 2007 | 09:23 AM
  #122
Yes, I misinterrupted your statement. The 4wd engaged xgauge information is new to me--can you repost this or redirect us to a link on this?
Old Nov 19, 2007 | 11:30 AM
  #123
DesertDog's Avatar
Look at post #7 in this thread. I am constantly updating the list. Hopefully people will report back problems if they find any.
Old Nov 19, 2007 | 02:31 PM
  #124
Default SGI Conversion
Since I had the SGI I saw no reason not to put it to use as well.
So I did a little SGI conversion today.
-John
Old Nov 20, 2007 | 03:58 PM
  #125
Carl, I tried your 4WD value and got no display on the Scangauge either during the am or pm commute. The unclear photos were taken at 5:40am today.
File Type: doc
Old Nov 20, 2007 | 07:15 PM
  #126
DesertDog's Avatar
You should not have gotten a blank display. Are you sure you coded it correctly? I double checked it and it is correct in post #7. It displays OFF in my FWD.
Old Nov 20, 2007 | 07:50 PM
  #127
econoline's Avatar
Mine reads "OFF" when sitting engine off. I haven't tried it under any other conditions. I assume it only goes "ON" momentarily when 4WD is actually engaged.
If Billy programmed his correctly and it displays blank, might this be another difference between the '05 and '07 4WD models, like SoC display on '05 but not on '07?
Old Nov 20, 2007 | 07:52 PM
  #128
I will retry on Weds and post the results. Most likely I did something wrong.
Old Nov 20, 2007 | 08:31 PM
  #129
DesertDog's Avatar
Perhaps, but I really suspect not. The PID is also used for a few other indicators, so I think it should work. BUT, I can see no reason why 06-07 AWD can't read the SoC PID, yet they don't. There is still a possible work around for this, but I haven't completely figured out how to test it out.
Old Nov 21, 2007 | 03:21 AM
  #130
EOppie's Avatar
HEV's are your friend
FYI I installed a SCII in my 06 4wd and my SOC appears to be working. Hovers around the mid 50's
