MMH Mud Flaps (Splash Guards)
Old Sep 28, 2006 | 04:48 AM
WaltPA's Avatar
Default Re: MMH Mud Flaps (Splash Guards)
Originally Posted by camedian
The trim around the wheel is a separate piece. I guess that's what you call the "fender flare."
Yep, that's it.
Sometimes it is in a contrasting color, like the lower cladding, and sometimes it is body colored, also like the lower cladding.
Old Oct 15, 2006 | 10:29 AM
camedian's Avatar
I spent the whole afternoon yesterday to install the mud guards. When installing the rear mud guards, I jacked up the car to remove the tire, but even when the jack was at maximum height, the tire didn't leave the ground like the manual says.
Do I have to deflate the tire to remove it?
Anyway, I was able to drill some holes at an angle and installed the mud guards.
Old Oct 16, 2006 | 04:03 AM
WaltPA's Avatar
IWhen installing the rear mud guards, I jacked up the car to remove the tire, but even when the jack was at maximum height, the tire didn't leave the ground like the manual says.
Did you have the jack in the right place? I know when I did mine, the crude pictograph showing the proper location for the rear jack point wasn't all that clear.
Old Oct 16, 2006 | 07:58 AM
camedian's Avatar
Yes, I did. I know it is dangerous to put the jack at the wrong place. I saw the body being lifted, but the tire didn't leave the ground.
Old Oct 16, 2006 | 10:17 AM
WaltPA's Avatar
That is why it concerns me. With the IRS, you should be jacking up the wheel/tire, and not the body.
Old Oct 16, 2006 | 06:39 PM
bill.flynn's Avatar
Thumbs up Re: MMH Mud Flaps (Splash Guards)
Thanks for the tip and part numbers on the splash guards Walt!
I bought mine a couple of weeks ago and they look like a perfect fit.
Now I just need to find the 1/2 day to install them.
Old Oct 16, 2006 | 06:50 PM
GeekGal's Avatar
Originally Posted by greenhybrider
I don't know how stupid I am, I checked and found out my FEH 06 already came installed with the "molded" splash guards. I agree the molded ones look really good.
Your profile says you have a Ford Explorer Hybrid. Typo? Or is the Ford Escape called the Ford Explorer in Canada? Confuzzled....
Old Oct 16, 2006 | 08:32 PM
camedian's Avatar
I got it. I was jacking the right arm but at the wrong spot. It should be the protuberance near the tire sidewall. It is lower than the more visible "joint" under the rear door.
The illustrations in the manual aren't that clear, and there is no text telling you what the parts are.
Old Feb 17, 2007 | 10:02 PM
jdp72's Avatar
Do these not fit the 2007 MMH?
Molded Splash Guards, Front - Black
(Part #1L8Z-16A550-BA)
Molded Splash Guards, Rear - Black
(Part #1L8Z-16A550-AA)
(Part #1L8Z-16A550-CA)
http://www.discountfordparts.com/MC-CBHF-BCJ.aspx
Old Feb 18, 2007 | 04:34 AM
WaltPA's Avatar
They do, but you need the rear ones which are not for fender flares (read the details on that webpage).
Of course, they will say "Ford" and not "Mercury" on them. That bothered me, and that's why I went with the Husky ones which have no name on them.
