Leaky vacuum hose check valve, TSB-22353
Old Jun 15, 2018 | 12:13 AM
arbie2's Avatar
Default Leaky vacuum hose check valve, TSB-22353
I replaced a leaky brake booster to vacuum pump vacuum hose (9C482) on one
of my three FEH 2012s/2011. The fault presented randomly with an illuminated
red dash brake light, and displayed text: "Check Brake System". The engine
would then run continuously (no battery hybrid mode) until restarted.
FORSCAN found two DTCs,
P1A1B - Brake System Control Module - Forced Engine Running
C1015 - Vacuum Supply.
The fault is documented in NHTSA ID Number: 10044540 and Ford's TSB-22353
(https://static.nhtsa.gov/odi/tsbs/20...44540-1228.pdf). The TSB applies to
2010-2012 Escape/Mariner hybrids.
Some 2010-2012 Fusion, Milan, and MKZ hybrids may have a similar leaky
vacuum hose check valve, NHTSA ID Number: 10042506, Ford's TSB-11-11-10.
Cost of the repair at my local Ford dealer was $432.
Old Jun 16, 2018 | 04:37 AM
Rex B's Avatar
Default Re: Leaky vacuum hose check valve, TSB-22353
Thanks for the tip. The hose is cheap and should be easy to change. I wonder what ran the cost up that high?
The vacuum check valves are cheap, might as well change that too. The Dorman 80189 and 80190 shows to fit 2008-2012 (may fit earlier, I didn't check). Under $3.00, and changing it is very easy.
Old Jul 21, 2020 | 11:19 AM
Chris Mo's Avatar
What ran the cost up so high? It's the Stealership way, what do you mean?
accent2010
Aug 29, 2018 03:25 PM
Brooklynhybrid
May 19, 2014 03:57 PM
us035976
Mar 12, 2014 12:52 PM
xraymarc
Aug 8, 2013 03:58 PM
xraymarc
Jul 30, 2013 06:14 PM
