Headliner repair suggestions?
Old Sep 9, 2020 | 10:15 AM
tommyball's Avatar
Default Headliner repair suggestions?
So the front or windshield edge of my headliner is starting to come loose and sag. I'm wondering what others have done to fix this.
I know there are clips for sale. Other sites recommend spray adhesive or double-sided tape.
I think some sort of a long plastic strip I could just clip along the whole front edge would work but I cant seem to find anything like it anywhere.
Thanks!
Old Sep 9, 2020 | 02:44 PM
accent2010's Avatar
Default Re: Headliner repair suggestions?
Buy the spray adhesive from auto store made for headliner. other glue doesn't hold because of the heat.
Old Sep 9, 2020 | 04:06 PM
fglaustin's Avatar
seems like it would be a problem spraying that into the area of the sag;
i have the same problem in my 2009 but it is all the way in the back end;
could one spray into an open can and use a brush to spread in into the needed area?
Old Sep 10, 2020 | 06:51 AM
ugmw177's Avatar
I use weldwood contact cement. Use the brush and apply a coat to the headliner material and to the base; allow to become tacky then press together. It does tend to bleed a bit through the material but not noticeable up by the windshield. What actually happens is the foam deteriorates [dry rot] and eventually the entire headliner will start to sag and need full replacement.
Old Sep 10, 2020 | 01:47 PM
Rex B's Avatar
Brush-on contact cement, as ugmw177 says.
Cameracarl
Jun 6, 2012 04:09 PM
rickkop
Mar 12, 2010 05:55 AM
fasteddie
Oct 16, 2006 09:28 PM
Pravus Prime
Oct 11, 2005 03:14 PM
